Leftcoast leftkicker;73128 said:
OK this is backwards from the Mikuni jetting manual which says to start at the opposite end (air screw, pilot, then slide, then main & then fine tune w/needle clip and air screw). I've been doing that and never getting the main larger than a 410-420. With the results I've had perhaps I should try your method instead?
What do you mean that you've "never getting the main larger than a 410-420?" You've never tried one larger? Or are you saying that running a larger one screws up the other circuits, that you already thought you had set correctly via Mikuni's method? If it's the latter...
I think Mikuni's method is fine... to start with. Say you use their method, and you get it nice and crisp and clean at idle, off-idle, and small throttle running. Then you go put my monster main in there. Ya - I wouldn't be surprised if the previously crisp small throttle settings became sloppy. IGNORE THAT - for now. Go and do the WOT blubber runs and plug checks and work down and get the "safe" main in there. Big enough that (provided we're good enough riders) we could just hold it wide open at 100MPH across Baja for 20 minutes at a time. If you never find your motor's WOT "blubber jet" then you never went big enough.
THEN - go back through the other circuits and clean things up. "The main only works at wide open throttle." Ya - blah blah blah. It begins to flow pretty early and has significant effect by 1/2 throttle, and becomes ALMOST the entire effect at WOT. The pilot is still flowing, too, but is minor compared with a 500-ish main. But the pilot does have to be considered for FINAL main jet selection. IMO.
So after you clean up the low end, then do the plug runs and get your perfect main, you'll probably be running a pretty big main and you'll probably need to go back and clean up the low end again... then ONE MORE TIME go out and make sure that your main is STILL large enough, now that you've reduced your pilot and maybe increased your slide cutaway and/or changed your needle or clip. They all overlap. And if you've reduced their contribution to WOT fuel flow, you may have to increase the main one more small amount to compensate. Trust me, this works.
I just skip one step and start with the main. In fact, I'd prefer to be fat on the pilot while I'm doing all this high speed stuff anyway. Only after I know I've got a big enough main to cool the motor do I want to start cleaning up the low end. Why? Because it's very common to seize these bikes at the END of a high speed run AFTER you chop the throttle. Why is that?
Because it was too lean at large throttle settings and the motor got too hot. Maybe not hot enough to seize at WOT, but hot enough that what "should have been" a rich enough pilot jet can't keep up when you close throttle and the motor's that hot. Seizure. Get a sufficient main jet in there that's doing it's job, and the throttle can be closed safely.
Sorry for the book, guys. This is important in order for us to protect our dwindling supply of vintage pistons and cylinders!!
