starter recall on xlites
I just bought my 2013 TE310. I asked the dealer about the recall and he said the work has already been done one the bike. There are already a few reasons that I have to not trust him...does anyone know how I can visually verify if the upgrade has been accomplished?
Thanks
Apparently this only involved early 2012 bikes as per recalled serial numbers in a bulletin in this thread.
Internal, don't see how you could verify.
Thanks
The recall was only required with specific VINs. My buddys just bought 3 TE310s. Only 1 needed the update.
2013 txc 250 vin # 1 to #223.2013 txc 310 vin # 1 to #261.2013 te 310 vin #1 to #203.​
Note only 2013 models.
I'm just passing this along and don't have access to the bulletin but have seen these numbers.
My POS husky is a 2011 TE310 I have had electrical starting issues since the beginning and it's back again. The dealer replaced all these parts last year and my concern is that they used parts that have now been recalled. I have been so pissed with this bike that I have just tossed into the corner of the garage and just started riding my KTM 990 adventure more. Is there anyway to check the parts themselves to tell if they are the ones that are recalled or should I just be moving on from Husky and buy another Yamaha?
my 2004 yamaha has had much less issues then my 2010 te250 :rolleyes:
There is no way to tell they just hardened the gears and look alike,he could show you the take out ones as they are held for warranty inspection.We modified the decomp springs on 2011 and 2012 models and set decomp valve clearance at .005 really helps,also we have had the starter wound heavier wich is about $245 exchange wich also helps durability.
