neversurfaced;9511 said:So, it looks as if the decomp valve / cam is the culprit. “No abnormal resistance exists in this system” according to my consultant. He better have been right, because I had to pay dearly for that edict (someone pass the highland!)![]()
So now my more serious concern: Can I run the LA to Vegas DS run after T-Day with this affliction, or should a get my ass down to Santa Ana on the double ? :cripple:
MOTORHEAD;9559 said:Seriously, does anyone know how this auto decompression system works? My bike has never spun over if it lands too close to TDC on the compression stroke without using the manual decomp.. So if there is a automatic system that should be working I need to fix it.
MOTORHEAD;9995 said:Scott Summers wrote in his DirtBike mag. artical; "Did you know the TXC (carburetor) and the TE (fuel injected) both have kick and electric start and they will start dead engine as fast as a two stroke?"
I'd have to say "NO" to that, because mine has never been that way.
Is that just the TXC's ?
MOTORHEAD;10279 said:I ordered a battery tender, a new Valve lifter, valve shim kit and have a new battery. I'm going to try and get all this stuff working 100% and see if I can get this thing off the line with the pack. Then maybe I can start winning some races again.
Xriderdown;12342 said:M, what does the "valve shim kit" consist of. Is Husky making some kind of camshaft shim like I rigged up?
neversurfaced;12376 said:I ordered a new decomp lifter from Hall's along with the tech manual CD. Haven't gotten them yet, hopefully soon...
MOTORHEAD;12381 said:These are just the standard valve shims. What did you rig up?
That's what I used to take up the slack in the camshaft side-to-side movement. My dealer had a few extra shims with different thicknesses hanging around and gave them to me. I use only one.
I just can't help but to chime in when I hear of TE510 starting issues. It's the only tangible issue I've had with my TE, all be it a very frustrating one.
Good luck!
