TE 630 MY2011 – Clutch basket: installation procedure and location of the 12 cup-shaped washers
Duncan_Idaho
Hello everyone,
I own a 2011 Husqvarna TE 630, 21.000 km, and I need some advice regarding the clutch basket assembly.
My mechanic has never carried out this particular operation and is not familiar with the arrangement of the cup-shaped washers, flat washers and Belleville washers fitted to the clutch assembly.
I would therefore be very grateful if someone who has actually performed this job, or has reliable technical documentation, could describe the procedure step by step.
In particular, I would like to understand:
What is the exact assembly sequence of the cup-shaped washers, flat washers and Belleville washers?
Where exactly is each component installed?
In which direction must the Belleville washers be fitted?
Are any of these components fitted inside the clutch basket, behind it, or in another location?
Is there a specific procedure or tool required to disassemble and reassemble this arrangement?
There is one point I particularly cannot understand.
In the 2011 TE 630 clutch exploded diagram available here:
https://shop.italhusky.com/en/products/2011/sm-te-630/primary-drive-clutch-85
only one cup-shaped washer appears to be illustrated.
However, the parts information seems to indicate that 12 cup-shaped washers (part no. 800054463) are required.
Are we absolutely certain that all 12 are required?
If so, where exactly are the other 11 washers installed? Why are they not individually shown in the clutch exploded diagram?
I would particularly appreciate:
clear photographs of the clutch basket with the components in their actual positions;
photographs showing the assembly sequence;
a drawing or technical explanation identifying the location and orientation of all 12 cup-shaped washers, the flat washers and the Belleville washers.
I am trying to establish the correct original factory assembly, not an alternative or modified arrangement.
Many thanks in advance for your help.
I work in the field of mechanics and it's pretty common to only draw one part per each group of identical parts, in such a diagram. Most likely, in the original spare parts diagram, they have written something like X 12 in the components list. They also only show one rivet as component #29 or one driven disc, #56, for example.
You can find pictures in this thread and I suggest that you read this post in particular since it has a step-by step guide.
