TE310R 2013 FI / Injector Problems
remmbremm
Hey everyone,
i recently bought a 2013 TE310R xlite in mint condition (~ 500 km). The previous owner told me had to replace the injector and fuel pump (gave me the old injector with the bike).
When i picked it up it was running fine (except for the electric start) and behaved normally.
Before my first ride i did some maintenance, checked the valves and removed the starter motor and worm drive. I then had it registered and on the first test ride it died on me.
So after around 6 km in the first ride it lost power. I stopped to check and it showed the following behaviour:
- engine running normally in idle
- as soon as i was opening the gas it would stutter and then flame out
- started again on the first kick but it was not possible to ride, immediate flame out
On the next day it would start 2 or 3 times, but now its not running at all.
I pulled out the injector and it does not spray any fuel while kicking over the bike.
- pump is priming while kicking over
- pump runs when applying 12 V directly
- Injector opens when applying 9 V directly and has a good spray pattern when connected to the tank
- Injector sprays when opened manually and the bike is kicked over
- i connected a bike light bulb to the line for the Injector and it flickers when i kick the bike
- i confirmed the key on the flywheel is not sheared (also removed the starter wheel on this occasion)
So now I'm hoping the Injector is faulty. Is it possible they can become "sticky" and don't open fast enough from the impulse by the ECU?
Or is my ECU shot?
Do you have any more ideas how to diagnose the problem?
Where can i buy a compatible Injector? The markings on the ones i have give me nothing (Keihin L DB12 and Keihin K BC05).
Thanks in advance
