MXRider
no, the more offset you have the less stable they are at speed. (typically on a dirtbike with 17s)
offset of triple clamps is measured from center point of head tube to center point of fork tube.
some supermoto triples are as low as 12mm offset because of wide rear tires and a shorter wheelbase.
those FBF triples you posted in the other thread that are 23mm are gonna be no better than your OEM clamps. (performance wise)
