Assembling the carb today after cleaning and I discovered I am missing the float pivot pin.
Anyone have a spare I could purchase?
I noticed that little notch you put in the slide Steve. Did make a big difference?
Not a big difference, but one I felt was worthwhile.
The notch in the front (intake side) of the slide did help the transition from closed throttle to small throttle openings, less 4 stroking/ better response, in my opinion. This mod came from the HuskyClub newsletter mentioned above. Here is a picture to illustrate. The small hole in the carburetor body directly in front of the notch is where the idle fuel/air is fed into the intake. The notch cut in the slide allows a small stream of airflow across the hole that helps to better atomize the idle mixture into the intake, even with the throttle closed.
