84 CR250 Issues?
Discussion in 'Vintage/Left Kickers' started by oregonsage, Jul 23, 2013.
  1. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    I have my own ideas on the cosmetics.....pics when I get there. Lets just say Im not a fan of the milk truck look.
    Got the front brakes freed up and working (thanks to Bill for the cable). Trying to remove rear shocks....ITCs are frozen to the swingarm mounts.....cant get any leverage on those little allen head holders so probably need to cut them free, mount new bolts and put in new heim bushings...
    Front end had a Trelleborg on it with a german tube inside....tire is very worn out and starting to crack and the tube still holds air...wonder if it is all original. Rim is in such good shape it may have never seen a tire iron before.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Well, the vintage husky bug just bit you! Congrats on ur new old bike.
    Sounds crazy but I enjoy redoing bikes just as much as riding them.
    Was it one of them old red tubes?
  3. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Get the nuts off the lower shocker bolts and put some wood on them and give them a bit of a tap. some heat will also help to free them up, you shouldn't need to cut them, hit them with plenty of WD 40 first.
    Just rode a sloppy wet event so don't worry about the graphixs too much. it can be showroomed when your too old to ride:D
  4. oregonsage 4st Clerk
    Dry Washington
    FX450
    Tube is black, has a Made In Germany stamp ....in English :-) Maybe Metzler?
    And I agree on the tinkering vs riding. If I could ride out my back door like I did as a teenager that would be one thing, but I can walk to the garage during a commercial break and then stay as long as I like.
  5. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    use "Deep Creep"on those shock bolts, let is soak in & tap like Suprize suggested, don't cut them off , cause there not standard bolts.
    Husky John
  6. oregonsage 4st Clerk
    Dry Washington
    FX450
    I gave up and cut one loose....bolt is frozen to the heim joint. I will marinate the other one a bit longer and see if I can pop it loose. I see that Halls shows the bolts available on their website for $17 USD each....or there are nice Titanium replacements from HVA in the UK for considerably more. Will that make it a 'works' bike it I put titanium on it :)
  7. oregonsage 4st Clerk
    Dry Washington
    FX450
    Deep Creep.....havent heard of that one....been using PB Blaster for a few years and this is the first time Ive had any trouble freeing something.....and that includes a bunch of rusty old Volvo parts.
  8. oregonsage 4st Clerk
    Dry Washington
    FX450
    Im already too old to ride...or at least my knees think I am many days... Yes making it pretty is a backburner project, I would rather get it dirty first.
  9. ruwfo Administrator
    NJ
    I used PB Blaster too, but that stuff stinks, i found Deep Creep a while back when i had a bunch of rust motor parts, i found it works better
    & doesn't smell up the garage. http://www.seafoamsales.com/deep-creep/
  10. ruwfo Administrator
    NJ
    Actually MCMaster Carr, sell shoulder bolts that will work & there sure not $17 each:censored: , i've have them on my 84 510 .
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Shoot me a pic of two bolts. I might have an extra pair I can send you.
  12. oregonsage 4st Clerk
    Dry Washington
    FX450
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
  14. oregonsage 4st Clerk
    Dry Washington
    FX450
    That would be sweet if you'll part with them.
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    No problem, PM me your cell # and I will text u pics tonight.
  16. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    ive been using deep creep as well...found its much better than pb blaster...takes heat a bit better too!
  17. oregonsage 4st Clerk
    Dry Washington
    FX450
    Voila....you da man!
    Shock bolts sunning on my deck in Oregon. Ive been soaking the mounts in Deep Creep for a couple of day....time to break out the extractors and finish the job.
    Cafe Huskivites are the best. Many thanks to dartyppyt !!!
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Your welcome. Good luck gettin them old ones out.
    You might need big hammer, then have to sound it out like PVDUKE would!
  19. oregonsage 4st Clerk
    Dry Washington
    FX450
    Bolts are finally out.... mo heat, bigger hammer. Got my brother to help; he has the big tools. Now to replace all of the bushings and bearings in the rear end and put it back together.
  20. Scott Stanford Husqvarna
    whatever happen to this project ? I'm working on the same bike
