Any Interest in a 630 Sidestand?
Discussion in '610/630' started by Kenneth Webb, Jan 8, 2012.
  1. Mark Nave Husqvarna
    TR650
    FE570
    I second the SimpleOne
  2. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    I have a new shop under construction right now, and Maybe, when it is completed, I could fab a few stands. But, it will be a while. I have concrete in but framing hasn't started yet.
  3. WickedWill Husqvarna
    QLD,AU
    some little red ones
    Any chance of some measurements of your stand Ken?
    From the bolt hole to the foot[2] and kick out [1].
    Think i might have found a stand from another bike ,they have a couple of different versions ,hoping one is close.
  4. Stujam Husqvarna
    Brisbane Austrlia
    09te610, 11te630
    I am keen if you find something that works better then stock Will
  5. Kenneth Webb Livin' It Up!
    Tucson AZ
    I would measure, but my bike is currently in California at Zip Ty's, while I am at home. Maybe another member with my stand will do the honors?
  6. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    Also interested in a new side stand having bent the alloy one. New OEM is $230 but I suspect there's better option out there cheaper. Aside from Ken's prototype from a 610, what other options are people seeing?
  7. alpha26 Husqvarna
    Australia
    2011 TE630
    BMW F800GS, Ducati Multistrada
    I am also interested in buying one, but I am from Melbourne. Would you still be able to ship one to me when you are ready?
  8. Kenneth Webb Livin' It Up!
    Tucson AZ
    Sorry guys, and gals, but no more stands. No plans to make any more, but as mentioned before, you can modify a stock steel 610 stand to work just fine. Look at my original thread for how to do it.
  9. Stujam Husqvarna
    Brisbane Austrlia
    09te610, 11te630
    I have been trying to find a 610 stand to mod... no luck might need to find someone handy to make me a stand
  10. Kenneth Webb Livin' It Up!
    Tucson AZ
    You can do it. I made one from scratch for my TE310 which has the same crappy stand as the 630. I made the top lug from three pieces of steel plate, welded together, since I couldn't machine one from solid stock. It's mainly hand work with a saw and grinder.
  11. WickedWill Husqvarna
    QLD,AU
    Been playing round wirh a drz one.Looks like it will be easier to make one from scratch.Kenneth's method or the old husky way of a piece of flat bent into a U.I have a lathe and am in the middle of setting up my workshop.If you aren't in a hurry I can let you know when I get around to finishing a stand .Going back to work next week will eat into my spare time.
  12. Tom McCutchen Husqvarna
    2011 TE 630
    Aprilia Caponord ETV 1000
    Hi Kenneth
    What year model 610 stand did you use.mine is bent. I want to replace it with a steel one and modifying the 610 stand looks better than making one from scratch
    Thanks Tom mcc
  13. Kenneth Webb Livin' It Up!
    Tucson AZ
    Tom, I don't know the year. I called Halls and ordered the most recent year that had the steel stand. The reinforcement piece that I added is the most critical mod, along with a steel "stop" which I hand fabricated and welded to the stock bracket. Lengthen the stand to suit. Works great and mine has been subjected to lots of use and abuse with no issues at all.
  14. Tom McCutchen Husqvarna
    2011 TE 630
    Thanks Kenneth
    I had a look at a DR 650 stand and it may work with some slight mods.
  15. WickedWill Husqvarna
    QLD,AU
    Bumpity if anyone can help me out
    Workshop setup and am ready to go
  16. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    I'll take some pics and measurements of mine when I get home from work. It works really well, perfect length.
  17. Kenneth Webb Livin' It Up!
    Tucson AZ
    I will do the same later this morning.
  18. Jason Lainesse Husqvarna
    Alberta
    SM 630
    I have this stand its so awesome. I have the old one in perfect condition if anyone is in a bind
  19. Kenneth Webb Livin' It Up!
    Tucson AZ
    OK hope this helps. The finished length of the tube is 14" from the bolt hole to the longest part of the stand. It is cut on a compound angle so suggest you leave it a little long and scribe to the floor to fit. I put a 3" diameter pad on the bottom. There is a 20 degree angle between the lug and the tube. Are you using the steel 610 stand for starters? If so, sawcut about halfway or more thru the tube right at the lug and bend to get it right, like I did, then weld it up. The stand should line up nicely with the swing arm when up, and project 8" from the footpeg pivot pin to the center of the tube at the bottom, and should be 1.25" forward of the center of the peg pin. This is as viewed from the top looking straight down. Be sure to double up the tube at the top for strength, or I think it will break. My prototype is going strong after thousands of miles on a fully loaded bike.
  20. WickedWill Husqvarna
    QLD,AU
    Thanks much appreciated.
    I will be building from scratch , hopefully strength won't be a issue, going to run a thin piece of flat from the top of the lug down about 125mm on the tube like a lot of other brand stands.
