BaronVonDarrin
where is the video on how to do this? I dont even know what tool I need to measure whatever the hell where ever the hell...
Seems tight to me, which would explain the hard starting symptoms I've been having since getting the bike back from the dealer.
Ha...that one comes out first, it's the main drain.I know about the magnetic plug, but I didn't take that out till last.....
Ha...that one comes out first, it's the main drain.![]()
Are you mixing metric and English in that post?
The gage "goes" when it slides completely between the lifter and the tip of the valve.
If it doesn't go entirely under it, try something smaller until you find something that fits.
The spec has a max and a min to ensure proper valve lift AND consistent valve clearance. If the clearance is too small (as some valve clearance shrinks over time as the valves and seats wear) you can begin to wear the lifters and cams by trying to hold the valves open.
To be clear the specs are 0.004"-0.006" for the intake and 0.006"-0.008" for the exhaust.
