woody's wheel
A customer called our attention to this thread and question on the cush hub. Looked into it and as long as you have a Husky hub with the 4 mounting bolts on the disc side, then Rad has a cush hub that will fit. You can use existing stock rotor & sprocket and hub comes complete with bearings, seals, and correct external spacers. The actual billet hub including carrier & rubber dampeners is $549 in any color. To our knowledge you cannot use cush hub from KTM on this model without several modifications and needing to use KTM rotor.
Breakdown for full wheel:
Good:
$88 Lace & true
$120-130 Pro Wheel rim or similar
$85 Rad Spoke & Aluminum Nipple Kit
$549 Billet Rad Cush Hub
$842-852 Total
Best:
$111 Superlace & True
$150-170 for Excel Takasago or DID Dirtstar rim depending on color, $229 for Excel A60 or DID LTX rim
$125 Supersize Stainless Spoke & Stainless Nipple Kit
$935-1014 Total (depending on rim)
The Superlace wheel will be far superior and have far less maintenance than the good wheel.
Thanks,
Chris
Good:
$88 Lace & true
$842-852 Total
Best:
Thanks,
Chris
