Kush sprockets for the husky
Discussion in '610/630' started by WickedWill, Jul 21, 2013.
  1. Kickaha Husqvarna
  2. trav72 Husqvarna
    NJ
    I guess that all depends on how much time you'll be spending on the tarmac. Must do? No. But if you can afford it and plan to do a lot of road miles, it certainly won't hurt in preserving counter shaft life.
  3. RDTCU Husqvarna
    '11 630SMS
    Just ordered a 41T for the SMS, we'll see how it goes.
    Hopefully I've got enough adjustment not to need a new chain...
  4. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    I defiantly want to know how this works out.
  5. R_Little Husqvarna
    NJ
    6k miles and the shock springs on my 610 clutch basket are getting worn.. so is the brass sleeve.
    I just bought a new clutch basket.
    I may try these to help out the clutch basket in the future.
  6. RDTCU Husqvarna
    '11 630SMS
    I'm at 12k miles on my 630 with barely a scuff on the clutch springs. I did replace the basket bushing around 8k miles and file the clutch basket fingers smooth.
  7. RDTCU Husqvarna
    '11 630SMS
    Got it in and on. The stock sprocket didn't have a lot of wear for 12k miles, and I didn't need a new chain going from 38T to 41T.
    Took it through the neighborhood, I'll get a bit more riding on it tomorrow to see if there's any noticeable difference...
    Coffee likes this.
  8. RDTCU Husqvarna
    '11 630SMS
    Well it's definitely much smoother on takeoff and on shifts and I can feel the few extra teeth on acceleration.
    Now we'll just have to see how it holds up long-term :)
    rajobigguy likes this.
  9. RDTCU Husqvarna
    '11 630SMS
  10. Chillybean Husqvarna
    Canberra
    TE 310, SM630, 72 WR 250. 89 WR 250
    What about cruising speed, will those extra three teeth slow you down much?
  11. RDTCU Husqvarna
    '11 630SMS
    Ratio wise, it's just short of throwing on a 14T front.
    My max speed should be around 103, down from 110.
    I normally cruise around 70, now the sweet spot seems to be around 65-66, but 70+ isn't uncomfortable.
  12. Chillybean Husqvarna
    Canberra
    Now you have had it on for a while what do you think?
  13. RDTCU Husqvarna
    '11 630SMS
    Still love it as far as the feel and smoothness.
    You can tell that half of the little rubber inserts are being compressed pretty hard, and the other half are pulling away from the inner ring a bit. Massive 630 torque and all that, haha.
    I emailed Kush to see what they thought about it but got no response. I'm not too worried about it unless inserts start falling out like they would in the first gen...
  14. Radar Husqvarna
    Southern Nevada
    2012 TE449
    +1
    Almost 2000 miles with no sign of wear.
    Pepper likes this.
  15. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    My theft recovered bike had my cush hub KTM woodys wheel on it for most of it's life. It only took a bearing swap to accommodate a different size axle and it was a straight swap. I'll have to check it and see how the basket is holding up. I don't like that my sumo isn't cush, so these sprockets are a nice option to have.
  16. Xcuvator Husqvarna
    Scholls Oregon
    yes
    My Kush has only 1500 miles and I can see small gaps between the rubbers and the metal. Time will tell. Sure makes the bike feel better.
  17. WickedWill Husqvarna
    QLD,AU
    some little red ones
    Mine lasted 7500km.The teeth were still good just the rubbers were busted,they didn't fall out just felt a bit jerky on roll off.Kush got back to me and said there may have been a faulty batch.Ryan from kush sorted it out for me and he has sent another sprocket.Excellent customer service for me.
  18. WickedWill Husqvarna
    QLD,AU
  19. Chillybean Husqvarna
    Canberra
    finally ordered a 41t for my sms.
  20. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    With significant wear showing up on my output shaft I am a little late ordering a Kush Sprocket, but I finally bit the bullet and one is on the way. Lots cheaper than the cush hub and hope it lets my splines last a while longer. The output shaft will eventually have to be replaced though, and maybe a cush hub will happen at the same time.
