I'll have to hash out the ideas a little better first. Might do some physics and bust out the pencil and paper and do some calculations as well. Keeping roughly the same lever feel, with just a lighter pull will be a bit complicated.
Clutch pull seemed lighter initially before the thrash test. I used an extra clutch actuator from a 360, that seemed to be about a 1/4 inch longer on the arm, which should have given some of the mechanical advantage others have used by extending the arm. The cable I was surprised with. It still flexes. I was under the impression that the $40 (3 month wait) longitudinally wound cables would not compress like that. They still do.
Hydro clutches, I'm trying to avoid. I've had some bad experiences with them in the past. When they work, they're great. When the seal lets loose and you have a loose lever flopping around, they don't work so hot.
Suspension works real well as is, but it always seems to work better after it gets all changed around by someone else. Maybe it's the weight loss from the $500 in my back pocket. Right now, I've only got new springs in it, 48/5.8 I believe, clickers adjusted around for the best feel on that day's terrain. Works good, but it's more a question of how good could it be.
