Hi all,
I have a WR300 2010 and have found a 6 speed tranny from a 92 wr250. I like the idea of the extra gear as I find the actual five speed pretty slow in fifth gear.
What I don't like is to disassemble the bottom end right now as I have just put a new piston and don't want to open it up again... But maybe I will buy it now for later.
I was also thinking to get an entire WR360 motor and do a swap... But I have a lot of doubts with that. If I get your first messages right you commented that the 360 is somewhat boring, but now you are missing it... hehe. What are the main differences between the WR360 and the WR300 ? Do 50cc make a huge difference ? Is that engine (still) harder to start ?
WR360 motor in 2010 chassis or WR300 with 6 speed tranny ? What is better ? hehe
Thanks for your answers.
What was the cause of the previous 6 speed disaster ? I think the gearbox should stand well the power of the modern bikes, the 360 has more torque and use that same gearbox ...
they did make a 4 speed in the early 80's, and yes, the gears are huge.
I suppose and hope that this was the problem..First problem found. This might have been the cause. Somehow the pin came out of the power valve actuator. And the bearing, which is the same as the clutch throw out bearing, but doesn't have a keeper for the needles, came apart. All but one of them are accounted for. Found them throughout my oil. The magnetic drain plug had not caught them all.....
Regarding the dimensions of the transmission teeth, I found some photos here on the forum regarding the Cagiva 5/6 speed transmissions and If I'm not mistaken our motor is the Cagiva one and from the photos the gearbox seems to be the same.
http://www.cafehusky.com/threads/question-on-cagiva-250-6-speed-transmission.39281/#post-376800
I really don't appreciate a big difference in the gear size, the gears are closer to each other but not a lot narrower as it seems...
Well, I think I will buy the gearbox and left if in the shelf until I need to touch the bottom end, If I don't get to the point of mounting it I can still re-sell it IMHO
Regards and Happy New Year !
Any news about this ?I still haven't gotten my tools back to split the cases, and haven't had time to do it even if I did have them back, so I can't say for certain.....
