sonicstate
Has anyone actually found No Toil air filters that are made for the TE630? They don't list any on their website. Thanks.
Sure haven't. I use OEM; that's the only option I've been able to find.Has anyone actually found No Toil air filters that are made for the TE630? They don't list any on their website. Thanks.
The green no-toil will eat Twin Air filter glue after about 3 cleanings. Found out the hard way.
No Toil replaced the filters and sent me a few bottles of the good stuff (w/ alcohol).
Skip the green stuff
O SUPER... the green shiz is what I've been using...
I'm tired of the PJ1 can tips clogging... I buy a can for $11, and the tip clogs and won't spray like it should. I put the can under hot water to build pressure, and clean out the tip, and it works for about 3 more seconds before it clogs again. Has happened on both the cleaner, and oil, on at least 6 different cans, before I got pissed and tossed them. Thats the only reason I went with no-toil.
I NEVER had that issue with PJ1 until about a year or so ago and now they all clog. WTF? Just get the notoil filters and move on.
...there was always a puddle of it from the bottom of the air box to the floor in the summer. The filter would seem dry after a couple of weeks and dirt in the boot.
but it usually needs to be cleaned after a few rides.
Also curious if greasing the sealing edge of a filter is common or just with No Toil?
Interesting, are you saying you feel they needs cleaned more often? I'm am fine with this as it is silly EZ but just wondering.
I use the super sticky PJ1 and Uni filter oil. I figure if it's easy for me to wash off, it's also easier for it to come off on its own. I'd rather have the pain of getting sticky every once in a while than have a sad engine.![]()
