Oil Change & Other Questions
Discussion in '610/630' started by Jim M, Sep 11, 2011.
  1. RDTCU Husqvarna
    '11 630SMS
    I tried the Rotella T6 5w40 on my last oil change. Then I bought a case of the good Castrol race 4T 10w50.
    I've used Mobil 1 as well.
    The 5w40 Rotella made more valvetrain noise than any of the other's I have tried, even after a valve check. I haven't run it for longer than ~1500 miles, but I don't think I'll be using it in the bike again.
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    I'm surprised about the mileage of the 1st oil change. I've done mine at 70-100 miles. Not saying it's super critical but better to know sooner if you have excess metal circulating around in there and figure out why.
    Mild weather areas like So. Calif 20/50 is a good choice that's easy to find. Some filters bypass (with too much throttle) on cold start with a pressure valve so best to warm up for 3 min or so.
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I recently switched to Amsoil and the bike shifts a lot easier with it vs. Rotella.
    cjoecruz003 likes this.
  4. cjoecruz003 Husqvarna
    Vacaville, Ca
    2006 SMR510
    +1 on Amsoil! My 610 shifts a lot better and the usual "change the oil when shifting gets harder" isn't as noticeable. When I change the oil it always looks and feels like I changed it too early!
  5. boxofish Husqvarna
    Surrey BC Canada
    Which Amsoil grade are you guys using?
  6. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    10W-40 synthetic motorcycle oil
  7. cjoecruz003 Husqvarna
    Vacaville, Ca
    2006 SMR510
    Both the 10w40 and the 20w50 are great.
  8. 1lunger Husqvarna
    Bloomfield CT
    Motul 10-60 is a great oil to run in the 610 too! Shifts like butter
  9. boxofish Husqvarna
    Surrey BC Canada
    Does anyone happen to have the sizes of the crush washers for the oil drain plugs for the 630? I want to order a few and don't have any to throw the calipers to unfortunately.
  10. Flynn Husqvarna
    England
    Very true, I came unstuck with the same thing and people didn't believe me on here, not naming any names but they know who they are and they even called my abilities in to question. Can you believe the cheek of it!?
    The sight glass is not the best.
  11. Flynn Husqvarna
    England
    So it is just synthetic oil that needs to be certified for motorbike use then?
  12. RDTCU Husqvarna
    '11 630SMS
    Is there a reason you're resurrecting every old thread you can find on here, SMJ and other places, flynn? And nobody really questioned your abilities, only your capabilities given your situation...
    Spice Weasel likes this.
  13. Flynn Husqvarna
    England
    I just like resurrecting old threads because I wonder if the OPs will find them afterwards. Anyway I did have a legitimate question as to the synthetic oils being the only oils that can affect the clutch or not. Why make a new thread when you can use an old, perfectly good thread?:)
  14. mekanik Husqvarna
    Kootenays, Canada
    I only question his judgment and tact!
  15. Rotax_655 Husqvarna
    If I can around the world
    ex TE 630
    Aprilia Pegaso 650 GA
    I write my experience here . I use for my motorcycle and car older and current oil Mobil 1 5W50 since 1988. 85,000 km with Aprilia Tuareg 350 wind 185,000 km with Pegaso 650 GA I had 0 problems with the clutch even if Mobil1 5W50 is a 100 % synthetic oil for cars Change always perfect My TE uses currently Mobil1 5W50 peak life I do not recommend different gradations
  16. Flynn Husqvarna
    England
    My judgement and tact? It's a question about oil grades FFS, how could it be untactful? It's not as if I have resurrected a thread asking if somebody died in the end is it!?
  17. RDTCU Husqvarna
    '11 630SMS
    He was referring to the same thread that you tried to dredge up...
    Yes, THIS thread IS about oil. Let's keep it that way.
  18. Flynn Husqvarna
    England
    Oh right my post #50, okay. That was me just being a little cheeky:D
