Power Commander 5 distributors
Discussion in 'TR650' started by pkplex, Aug 1, 2013.
  1. Motosportz CH Sponsor
    Myself, Ken, Dan from DJ and 2 others all had the hanging idle issue. I still have it but have not removed my canister yet. I ride ti as is and it runs good and I'm not bashing the product just want people to be aware that you might need to deal with it. I have the PCV with autotune. Might try and remove the canister today.
  2. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    When I get the PC5 is it possible to get one of you fine husky people who have the auto tune to send your map #'s over the net (email)? Don't even know if that's possible. So the cheap asses like myself can piggy back off your numbers lol.
    Figure the PC is a much richer map from stock and you guys with the Auto Tune have fine tuned it. I realize not all bikes are the same but if 2 bikes ride at the same relative AGL and have the same climate, it should be pretty dam close.
    Im guessing it would be like copying and pasting numbers from your spread sheet to the next. Not quite sure how it all works.
    First guy to send me their numbers gets a Tim Hortons gift card in the mail.
    once I get my exhaust
    First guy to send me their modded exhaust numbers gets a Tim Hortons gift card in the mail with actual money loaded on it. :)
  3. scotty Husqvarna
    chris 1261 said I think the autotune will also help if you travel through different altitudes and temperatures. It's constantly measuring the O2 levels in the exhaust and will fuel accordingly (in closed loop)
    That's exactly why I'll add an autotune to mine once I've had it on the dyno. Its a long story but
    I've not had my PCV re flashed yet. (my own fault)
    Scotty
  4. Motosportz CH Sponsor
    No problem, already several maps floating around via our Emails with Dan from DJ. Very EZ to send as it is just a small file and you can load it. I have not saved my autotune file to view it in relationship tot he map it was shipped with.
  5. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Same here. I was saving everyones maps and created all of those spreadsheets and graphs from them...until I got the A/T hooked up.
    I have a bunch of maps for the TR650, but here are a couple to get you started...
    Delnari and pkplex like this.
  6. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    Great guys thanks a lot.
  7. pkplex Husqvarna
    R6, Ninja 250
    Just ordered one :) No auto-tune gizmo as yet, will see how the standalone gizmo goes.
  8. Coffee CH Owner
    I've done PVC & Auto tune work before, highly recommend getting the Autotune if you are getting a PCV.
    I've written up why in EFI/carb area, look for threads started by me there.
  9. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    Maybe the wrong place for this but..
    Does any one else find their exhaust gets uber hot,real fast.
    My pipe is blue almost halfway to the cans. 5 minutes of idling you can't touch the mufflers.
    Wonder if it because its crazy lean. The pc5 should cool it down a bit. Did anyone else notice their exhaust gets crazy hot and found a difference after they installed the power commander.
  10. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Huh...not sure to tell you the truth. Sorry.
  11. Indorider Husqvarna
    Bojonegoro, East Java Indonesia
    2010 TE 250
    Yamaha TZM, Suzuki RGR (2 smokers)
    I agree Coffee. I played around with maps and settings and none of my fiddling worked as well as the Autotune does. After I activated it I was able to forget about it and just ride...
  12. Trapperj Husqvarna
    Knoxville TN
    Tr 650 Strada
    R1200 GS RALLY..KLR 650..Zrx 1200
    The hanging idle issue..is it now fixed with the auto tune? Thinking of the PC with autontune...I like the idea of set it and ride. I can never leave anything alone. My TR runs well now....but thinking there might be a little bit more to gain with the right tune...especially when exhaust become available. You guys that have the PC w/ auto are you constantly messing with it? Or able to enjoy? I'm itching to try it and see..
  13. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Just set it and forget it....
    ...but remove the evap canister too (if your TR came with one).
  14. pkplex Husqvarna
    R6, Ninja 250
    PC5 arrived today, will hopefully install it this weekend..
    Question though, the wire that goes down to the rectifier area, there are two plugs. According to the instructions I am to only plug one of them in... is the other for if I have an autotune which goes to the O2 sensor or something?
  15. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    The plug closest to the pcv goes right into the injector, the next plug goes to the TPS (pain to get to from side of bike up under the tank...but doable), and lastly two unterminated wires that go behind the rectifier.
  16. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Just curious what the cost of those two are? Please help get a bike to Rexxer. Talk to David, or Jeff or Abe, David is the owner and would do the programming.
    7331 George Washington Memorial HWY
    Yorktown, Virginia
    757.989.5000
    $600 and you don't have to add anything to your bike, no adding wires, modules, weight or anything, and you get the added troubleshooting functions of the GS911. (they need to see a bike in Calif.) Granted, with the PC5 you can switch maps on the fly, but that is it for advantages.
    Please tell me Terra owners aren't this dense.
  17. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    You can get a PVC and autotune for $500
  18. Coffee CH Owner
    I'm not terribly sure what your 'dense' comment was in reference to, hopefully not me.
    Regardless, start up a Conversation (was called PMs) if you want to address me personally.
  19. Abby Husqvarna
    uh-oh, Dad's pissed!!!
    kjackbrown and mag00 like this.
  20. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Nope, not aimed at you.
