Troy F Collins
Slowpoke;96259 said:Not exactly true - it's more of a complimentary feature.
Torque indicates how much load or work an engine is capable of. Horsepower indicates how fast it can do that work.
(at the crankshaft, without benefit of torque multiplying transmissions etc.)
Ie. an engine with 5hp and 100 ft/lbs of torque, could do a lot of work or get a large mass moving, but it wouldn't be able to move it very fast.
(Ie. large diesel truck engine as a real life example - relatively low HP to torque ratio)
Inversely, an engine with 100hp and only 5 ft/lbs of torque couldn't move much weight(do much work), but what work it can do, it can do very quickly. (ie. very small bore 2t engine on a light mx bike as a real world example - High HP to torque ratio)
Looks like Sean guessed it pretty close for the dyno run - 47hp vs, 46.8 actual - good guess!
Only torque can be measured....horsepower is a calculation...and the dyno does this for us
torque is simple...force times the distance or F x D
and horsepower is the maximum torque figure and how far the engine can rev while still applying the torque....relative to 1 seconds time
horsepower = torque x RPM divided by 5252
0r 550lbs on a 10in pulley moved 1' in 1 seconds time
only torque is measured on a dyno (with the rpm).....and the dyno gives us a figure
but enough...lets see some figures !!!
??? but i guess see is believing
