Ross Shafer
CH Sponsor
Thanks Kelly, I'll be in touch if I decide to get one.
Can I not ask how other riders have there bikes set up. However if 48.5mm is the only setting that everyone should use then my apologises.
Huh? No was not saying that was just letting you know a good starting point. By all means more info is good. Sounds like most go slightly leaner than me. 48.5-50mm
I would but there's nothing to add, it would read like this;Has/is any of you guys going to add your Lectron setup on to the thread: New and Improved Jetting Database?......Or even a new Lectron database?
I believe mine measured 49.5 too, as delivered from Lectron.My modified rod measures at 49.5 and is working really well so would appear to split the difference.
good to know that my method has issues.My original rod was at~50mm and it took 17.5 turns to get it out. I threaded the MS3 rod in 17.5 turns thinking that should be ballpark, but didn't measure length. The bike would barely fire even with the choke on and I ended up going in another 4 full turns to find its happy place.
the EZ way is to use this tool but it is $150 and not needed, Just get it close enough to start and then tune it a little and be done.
To clarify, WHERE'S MY NEW ROD?
Th
Thanks mate. Sound obvious but I walkways figured was rich on the bottom. Will try tomorrow!
MS-3 rod and PJ tube arrived yesterday and to show my appreciation 'Thank You Kelly'. Tomorrow I've a practise ride and will supply some feed back.
