Round two of the "other" carb types - Lectron
Discussion in 'EFI/carb' started by Motosportz, Dec 18, 2012.
  1. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    You could always run it out of fuel !! Personaly I dont think you will have a problem if you leave fuel in there as there is no jets to get clogged as per a normal carb.
  2. burstcasino Husqvarna
    Austin, TX
    2012 Husqvarna WR300
    2001 KTM 520 exc
    I hear ya because my wr is stored 200 miles away.(House remodel-full garage) Rides are a bout once a month unfortunately. I try to empty the bowl by running it dry. I've noticed the lectron seems to get a vacuum lock or something when trying to start it with the gas spigot closed. It will just refuse to start and then starts the ugly kick starter kick back. The lectron seems to have trouble when you close the gas spigot. I was starting the bike then closing the spigot, but I had trouble burning off all of the gas. It would die before all of the gas would burn off.
    I'll usually take off the tank and drain it since its a super easy to do. Then I turn the gas on and then start it up and run off what's left of the float bowl. Took awhile to get this routine but seems to work good. I hate leaving the ethanol in my bike if I don't have to.
    No problem with the Lectron, but I aint gonna remove the whole bowl to drain it. I thought about the optional metal bowl but really kind of dig the clear see thru bowl.
  3. sparky22 Husqvarna
    None
    Kawi
    If I could reach the power jet hose, I would just pop it off and drain the bowl.
    I already found out that the foam filter doesn't like sitting in stale gas for several months.
  4. Ruffus Husqvarna
    Not sure about your fuel there (heard storage horror stories). But here I just fill up the tank & put in gas stabilizer. Run the engine until I'm sure stabilized gas is going through the carb & that's it. Come spring time (4 to 6 months later) it always starts right up. No issues by having stabilized gas in the bowl.
  5. Motosportz CH Sponsor
    IMHO this is the best method.
  6. Vinduro Husqvarna
    Mississippi
    I just turn gas off and ride for a minute or two and then let it idle till the carb runs out.
    supervision likes this.
  7. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Yes this works for me too. I just experienced a stuck closed float valve from hardened fuel.
  8. david.bergen Husqvarna
    Belgium
    wr 125
    Ajp pr4 240,beta xtrainer,beta rr250
    Is this rod also usable with euro fuel?
    Do you have Euro customers feedback on this ?
    thanks,
    David
  9. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    My 300 is a screaming banshee with the carb now. Only quirky thing is when I first start bike it does this blub blub blub then quits. Maybe does that 2-3 times until its warmed up. Then its absolutely perfect. The bike runs so amazing now I suppose I could fool with idle but I don't dare even want to touch it because once its warmed its just a totally different bike.
    454x and Motosportz like this.
  10. Motosportz CH Sponsor
    I'm stoked you like how it runs but you should be able to dial in the starting. When you get time try going 1/2 leaner on the rod. If thats not good go the other way. You are right near the sweet spot you just need to tweak it some.
  11. Russ Henry Husqvarna
    Seattle Washington
    2013 TXC 310
    I rode a buddys KTM 300 with one. I could not believe the before and after diff between it and oem .
    Almost made me want a 300 smoker. Smoooth electric power bottom to top.
  12. Motosportz CH Sponsor
    Yep, thats how I got my 02 CR250 running with one now. Perfect woods motor.
    You need a 300 smoker Russ.
    454x likes this.
  13. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    um stupid question but how do you adjust metering rod? manual says just turn it but you gotta push it in first to turn then it feels like its just spinning. I know flat side gotta face forward but I cant seem to get any noticeable difference when physically measuring it. someone help me out please
  14. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    You just turn the rod without pushing it , Then you push it in to spin it so the flat part faces the correct way, easy peasy:thumbsup:
    You may need to use a set of pliers or suitable tool ( put a piece of paper over the rod first) I personaly have no problems doing it with my vise like fingers :lol:
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    thanx johnnyboy that's what manual said but felt very tight so didn't wanna break anything-will try some pliers, youre a legend mate
  16. Motosportz CH Sponsor
    Yes, turn the rod in 1/4 turn increments (in / clockwise for richer) and then push it up and reindex it so the flat side of the rod is facing the motor. These come setup well but every bike is different and some fine tuning will get the most out of it.
  17. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    question for you guys... i've been tuning the PJ on my 165, when you go richer on the PJ do you generally need to go a hair leaner on the rod? it feels like they overlap (mid / top) quite a bit on my bike but not sure if that is normal?
    EDIT: had my first stuck float with this carb last weekend. nice to be able to smack the clear bowl and see gas flow again but seems kinda premature to be sticking. i run 100% or 50/50 race gas.
  18. Motosportz CH Sponsor
    Yes, there is some overlap. You can control where they overlap by making the PJ tube longer or shorter. The shorter tube makes the PJ happen later / more opening. My newer MS3 build of the Lectron addresses this and uses a shorter PJ tube (in the carb throat). these are very inexpensive and EZ to change out if you wish to play with when the PJ comes into play.
    I have never had a Lectron float stick. :excuseme: Chunk of dirt maybe? Do you run a fuel filter?
  19. Motosportz CH Sponsor
    This vid is simple and most of it obvious but for those wanting confirmation of how to do it...
    ks9mm, 454x and typeone like this.
  20. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    thanks, yes, previously i had trimmed the tube a bit then moved to the shorter tube + MS-3 rod kit from you. definite improvement but i'm still ~2 turns or so out on the PJ. it's weird, seems to want more PJ the hotter the motor gets but then my mid gets a little too fat feeling. last weekend i leaned out the rod by maybe 1/4 and richened the PJ by 1/4. Sundays ride will be the next test but i'm planning to go another 1/8th out on the PJ and leave the rod.
    i had a feeling the stuck float was an oddity, cant remember reading about a single case on CH here. i'll strip it down and clean it. maybe a spec of dirt but yes, i do run a fuel filter.
