Switched 12v Power supply
Discussion in 'TR650' started by Gedge, Feb 22, 2013.
  1. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Sorry! My fault, i had a more precise look at the wiring plan :(
    Coffee is right, the connector is X9220B and not X9349B!
    So plug 83300402344 fits to X9220B and not to X9349B.
    Nevertheless i think i can use it for connecting an USB-charger, fuse which is 4A should be ok.
    So again the question: Does anyone know where to find X9349B which shall be the connector for additional accessory?
  2. SpittingCobra Husqvarna
    Albany Creek, Brisbane, Australia
    Tr650 Strada
    KLX400
    Left side, tucked up with the loom, just above the head.
    Nordland likes this.
  3. Baddrapp Husqvarna
    Yucca Valley
    TR650
    I am dumb when it comes to electrical. Basically this plug above the head can be used as a switched power to activate a moto brain, PDM60, or a relay?
  4. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    I was on a damn wrong way :mad:
    Now i found the connector which is listet as X9349B. Thank you very much SpittingCobra!!! :thumbsup:
    Cartool plug (83300413585) fits to X9349B, but you have to change the pins.
    Pin 1 is ground. Original Cartool power is pin 3. For connection to X9349B you have to change pin 3 to pin 2.
  5. SpittingCobra Husqvarna
    Tr650 Strada
    KLX400
    I also thought an accessory socket would be conveniently provided behind the headlight. Apparently 2cm above the hot cylinder head is a better location. What was I thinking!
    Badrapp, You can use the plug X9349b to power a GPS etc directly as the Gr Wh wire is fed from F2, a 15amp fuse. (Incidently, the brown wire is a conveniently provided earth for accessories). If you anticipate drawing more than a couple of amps then it would be better to use it to switch a relay and use a suitable in-line fuse and heavier wire to suit the load. Always have the fuse close to the battery so that it protects all the new wiring.
