Tech 3
This all started when I first got the bike a 2010 SMR 510,
the first thing I did was to put my Innovate motorsports LC-1
air fuel mixture gage on and started to log my A/F ratios
it wasn't pretty. The next thing I did was to buy a ibeat from Scott at semco
when I first hooked it up the TPS was off the ibeat came in handy there to be able to correct this problem. The i beat was able to set the CO's up to the point where there were no more flame outs and the bike ran a lot better.I spent all last summer trying to get my A/F ratio's to come in line where i wanted through out the O through wide open range and could never make it happen,no matter what i did i could not get rid of the 1/8 throttle rich spot right where i would cruse around at, I tested right up until the fall and never could make it happen my best settings ended up being CO1 97 CO2 100 CO3 100 and that is where i left off for the winter.
This year I was ready to try something new so I ordered a JD tuner an installed it,after about 200 miles of ridden and some calls to JD (BINGO) The bike is now set up runs perfect compared to my best efforts be four,now the A/F ratio is a flat line across the board I picked up 10 more miles be four my fuel lite comes on,be four lite came on at 51 to 54 miles now it comes on at 62 miles that is a big plus for me, with the accelerator pump feature the bike will power wheelie in third where be four it would only do it in first and second. pulls much harder all the way up to the point where it gets way too crazy for me to handle at my age, the bike never flattens out just keeps pulling like a Westinghouse locomotive.
Long story short, The ibeat,JD tuner and a air fuel mixture gage is one way to go.
The ibeat for setting up the TPS, the JD unite for making changes, and a air fuel gage
to make sure you aren't guessing at what you are doing.
