Time For New Drivetrain Parts
Discussion in '610/630' started by jtemple, Sep 19, 2011.
  1. pr111 Husqvarna
    I have never heard that evenly-divisible stuff. I would think the spacing remains consistent regardless of number of teeth (because the diameter changes along with it). I hope someone can confirm this either way. As to the front sprocket - I had the sprocket cover off doing some maintenance and I don't think you can get something larger than 15 teeth on there. There's a chain guide (I'm not sure what it's really called) up there that just fits the stock sprocket. I suppose you can grind it down to make room but probably not worth it.
  2. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    You're talking about the case saver. That arcing steel strip that keeps the chain from punching a hole in your engine if the chain separates.
  3. ContraHusky Husqvarna
    "...a wife's tale or superstition"
    Yes.
    I have a 15/45 setup on my TE with the same chain it came with. I have SM wheels that I swap on that have a 42 sprocket, without need to swap chains.
    I'm certain I could keep the chain with a 16...if a 16 would fit. It's a close squeeze in there...anybody know for sure, on a 630, not a 610...
  4. tool46n2 Husqvarna
    Chicago
    Already ordered my Suppersprox 43 and red chain....just trying to find some time to get them on.
    jtemple and Robertino like this.
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Nice. My sprocket will be the same, but I think I ended up with a gold chain. I didn't know I could get a red one!
  6. tool46n2 Husqvarna
    Chicago
    I've was actually on the fence. The red may be a little over the top but I figured what the heck.
  7. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I fired an email off to Supersprox and they said that the chain was only available in gold. :excuseme:
  8. tool46n2 Husqvarna
    Chicago
  9. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Ah, I see. Oh well, gold should look pretty good.
    I'm thinking about using a different chain lube this time around. I did get nearly 9000 miles out of an AL sprocket using Belray Superclean, but I've always felt like it was too dry of a lube and didn't really work its way into the links all that well.
  10. partypage Husqvarna
    I just purchased a 16 tooth counter gear, and all though I have not tried installing it, it looks as if there is no where near enough room for it. My installation stopped when I couldn't remove the master link plate off the chain(removed the safety clip, couldn't force off the plate) I didn't want to damage the chain because I don't have a spare. I suppose I could just remove the rear wheel and try it that way..
    I have a 2011 sms630
  11. RDTCU Husqvarna
    '11 630SMS
    Or buy a chain break... i usually just use a couple small flathead screwdrivers and work the plate loose, careful not to damage the o-rings.
  12. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Ah, chain removal. I can pop the clip off with a pair of pliers. Separating the link is a different story. I have this tool:
    I couldn't figure out a way to use it separate the master link without actually pushing the pins completely out of the master link. If anyone can help me out, please do!
    What I ended up doing is spinning the wheel around so the master link (with clip removed) is sitting on the rear sprocket. Then I just tapped on the master link pins with a hammer until the link came apart.
  13. ContraHusky Husqvarna
    You have to break the chain to replace the sprocket, even with the wheel off. As said above, you can wiggle that plate off with screwdrivers. To my surprise, the master link on my bike was missing one o-ring. I bought a few spares at the hardware store.
  14. partypage Husqvarna
    Thanks guys, I will report back if that 16 tooth fits or not!
  15. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    And a photo of it installed if not too much trouble. Sounds like it might be very tight fit so I'd like to see the clearance before buying one.
    _
  16. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I contacted Motion Pro about a tool to split the master link once the clip is removed. They pointed me at a couple of plates that should work with my chain tool. I ordered some up. I like having the right tool for the job. :)
  17. krazy1 Husqvarna
    wow that looks sweet when did supersprox start making different colors?
    and Did you order stright from them?
    and how long did it take to get?
    sorry for the questions im new to the site:thumbsup:
  18. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Supersprox makes all sorts of different colors. Check out their website. He got the chain from somewhere else, though.
  19. tool46n2 Husqvarna
    Chicago
    I did order the sprocket straight from their website. I don't know why but it took like 3 weeks to come in. Can't remember where I bought the chain but google "EK chain colors" and you will find dozens of retailers that carry them.
  20. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Well, that's not good news. I need my stuff now! Riding season is running out quickly!
