Fast1;5816 said:Is the 2" HID the same as the Trail Tech MR16 HID?
exactly
all components are from existing lights used already and tested thoroughly in the past
no performance or reliability issues
I will shoot pix of the husky graphics soon. They are red and white and look like this (kinda like the CFR one)...
Fast1;5834 said:what about all black, similar to the 08 TE OEM product?
Fast1;6986 said:any updates about this headlight from Trail Tech?
Coffee;6999 said:Anther thread about it in the Motosportz section
http://www.cafehusky.com/forums/showthread.php?t=654
Fast1;7007 said:thanks.. I should have searched
ElDiablo;7441 said:So I was ready to place an order but you only take PayPal? That takes forever to process.
Coffee;7443 said:Doesn't Pay Pay accept credit cards? That is how I used to do it before opening a Pay Pal account.
I forgot...I have it set to take $ from my account and that takes 5 days.
REDOVAL;7474 said:I picked up the Husy X2 setup from Kelly last week and the light is impressive. The intent was to replace the anemic factory headlamp on my 2007 Husky TE510 with something that people will actually see on the street and allow me to ride offroad at night without struggle. I have used trail tech HID products for some time and this light was not a let-down. I did have problems with the factory stator lighting it off. The stator output at the headlight harness shows approx 11.5VAC. When the engine is revved, the stator output drops to about 9VAC at its lowest. I ended up wiring the light directly to the battery using a simple male and female plug for the time being. With the light wired DC to the battery, the stator only very slightly maintains its charge. I rode with both lights on wired to the battery for about one hour and it survived fine. I rode with the light in combination with a trail tech mr11 hemlet mounted HID setup and it was an awesome amount of usable light even at fast trail riding speed. The stock setup was pathetic; in comparison this light is everything you could hope for with a minimal current draw.
I do have a couple of questions regarding the electrical setup:
Kelly, you have this on your 610 wired to the AC setup on your bike correct? Did you use the leads to the stock headlamp setup or did you run your own using the factory switch? I tried that method on the 07 TE510 and had problems lighting off the HIDs.
Would swapping the stator to DC output allow me to run the light using the factory headlamp wiring? I have yet to find out if the DC stator change is a help for these issues or just another way of doing the same thing.
Finally, changing the stator to a higher output model is a viable option as well. Does anyone have specific experience with replacing or upgrading the stator as it applies to the TE models?
Thanks in advance for your time and advice.
mrkartoom;9304 said:What's the story on the 70W halogen version of this light? Anyone using it yet? I'm curious how it would work for the street.
