1928 Husqvarna Model 200
Gott this from Edwin at the Husqvarna Museum.
There were no manuals for these.
The seller showed the operation and if it needed repair you went back to Husqvarna to have it fixed.
That's what i understand from our conversation.
Got my new Replica oil pump with the
Oil Policeman tell tail
Just have to do some machining of nuts and ferrels and I can repipe this and get to the part of running it.
I should have been working on the cables but am spread out pretty thin with numerous projects afoot.
I would guess that the dial for regulating the oil flow? Why? And whats the purpose of the smaller valve on the right?
this is a total loss oil system
so you dial it to where you can run and kinda burn it off and not fill the crank case otherwise when the oil is too much you can hear it in the engine and pump it out onto the ground hahahhahah thats how I understand it
the second little valve is a Oil policeman and pops out to tell you the pump is delivering oil to the bearings
wicked cool
this was made for slow dirt roads i suppose and the wide fenders were for clearance for snow chains I Hear Tell
On this setup you have to remove the oil from the cases with ah hand pump that is mounted to the side of the oil tank I'm not sure because I haven't totally disassembled this but I think that you can draw the pump lever out to suck oil out of the case and then close the petcock at the bottom of the pump and push it back down and refill the oil tank but I haven't tested that system yet kind of seems that way though the way it's built
This is where I manual would be super helpful but I haven't found one yet I've tried some of vinskord leads but nothing yet
May have yo try and get someone on the tele rather than email
Thats cool and it makes sense. Sounds like a progressive step in engineering to reclaim the oil compared to the Total Oil Loss system. I read that the Model T motor of that era had enough room for splash lubrication that reclaimed the oil. They did it with a series of 16 cups on a rotating wheel. Wonder when recirculating lubrication was developed. :thinking:
https://photos.app.goo.gl/Nun5tphjEb1hmU4e6
Got my new expensive replacement pump can't use it shaft drive flats are too big The old pump was drilled to a larger size after it was stripped. So I put the old pump on and re - pipped it behind the front down tube.
Added a quart of oil and put containers underneath we'll see if it holds oil overnight if it does tomorrow I'll see if I can make it start and see if it pumps oil what a pain in the ass
When I get ready for a full rebuild I'll re-machine everything and weld up all the stripped and damaged holes. And everything can be machine to the original specs.
Lots of issues here
Can only get a couple fires from it
Seem like not enough fuel so ill work on the timing
Also 75psi per cyl
Lapped the played out valves and got 90 psi per
Primer cup hols in the top of the head are stripped.
Got some plugs in there now
#2 cyl intake adjuster is stripped got it sng with some excess lash.
Center cases are a diffeent number than the outside covers and all are different from the factory # assigned to this frame
Used mt antique lapper , nice
O issues galore.
Moving forward
So after icing my knees and taking a nap I've made the decision that this engine is fubar.
It has to come out. It was blowing a lot of oil onto the plugs so leave us to say there's a good possibility the rings are shot also the valve stems have been shortened so the cam followers are at their furthest point for adjustment and the valve alignment with the cam followers is out by at least 3/16 of an inch all to be investigated when I disassemble this Pile O Shit!!!
I'm confident that when I'm done it will do what it's supposed to do the way it's supposed to do it for now she's going back together and undercover while I finish the marine motor. Thanks for watching Chris
Stay tuned for my Harley G Motor rebuild and upgrade to Magnum I think I got all the parts It will be another thread though.
I think I've got the timing correct now. How it ran even for a short while the way it arrived I have no clue!
Cleaned the pistons and a butt ton of carbon/burnt oil from the ring grooves.
No Change In Compression Numbers!
Looking to get some pistons and rings but still have to measure everything up. Hope to find an off the shelf that will suffice for now.
So I Bit the Bullet!!
Ordered 2 New Custom Pistons from JE Piston.
Expensive!! But they will be Perfect and Will Last for My Lifetime.
I will Be able to get rid of the cylinder spacers and have a REAL Oil Ring!! Not just some holes drilled under the lower ring.
When received I will take them to Power Seal In PA and have the Cylinders Bored to Match. So they will be Perfecto!!!
In the mean time I will reassemble the motor and after Figuring the Timing (did you see the timing gears were not set up correctly!! :mad: )re install in the bike and see if I can get an Real Idle and RIDE the POS!!!
After I get the Pistons and Disassemble I will clean and take the Engine Cases to my 3D printer and have 2 sets of them made in casting wax. Then take them to My Casting place and have them Poured with Aircraft Grade Aluminum!!
These cases are not Original to the Bike and are Mismatched among themselves. Recasting will allow me to Stamp the Original Numbers in the Cases to Make the Bike as Perfect As I Can Make It!! Saving the Mismatched Cases From The Embarrassment Of Their Heritage! Not Original But.....
Holy fricken crap, this bike looks like something a professional hack owned. Instead of asking whats wrong with it a faster response would come from asking whats right with it. Your persistance to continue is highly commendable. Keep up the good work my friend. When you're done with it I'm convienced it'll be 100% hack free. :thumbsup:
So true Daryn, I am Super Documenting Everything. I may not be able to get a Refund But I CAN Link this Embarrassment to the Consigner who In MY opinion had to Know the Condition Before the Sale!!
This was a poor decision on my part, but I feel it couldn't have happened to a nicer guy!! :p
Meaning If it can be fixed it will be fixed. At least I Know what I'm looking at and the proper way to remedy the Hacks!!
I've talked to a couple of the people that Vins was kind enough to advise me to and none can help with parts or wisdom it seems.
So this weekend the motor with all its problems will go back in the bike, and I'll try to coax it to run well enough to get a ride up the street.
Video will be taken either way. At least the timing looks correct to me!! I have a Magura throttle with the Mikuni so it should RIP!!:naughty:
And I hope not Rest in Pieces!!:oldman:
I was wondering what this metallic stuff on the cylinder was from?
Looks like they CUT the INTAKE with a Wizzer Wheel Without removing it from the Bike!!! :censored:
Looks like they painted the tank on the bike too!!:banghead:
