1928 Husqvarna Model 200
Im pretty sure it was the cap on the oil policeman on the oil pump.
I got it tightened down an mow th only oil is from the timing cover and trans kick cover.
I will be making them new gaskets
Curiously i thought there was oil blowby the pistons but the plugs are dry ond there is a access hole at the collector for the pipes and a finger in there shows no signs of oil.
I am very glad for that
This was today
Bjorn made a chart for the ignition thati i translated.
Thanks to Bjorn!! Having a contact and Friends with the same bike is invaluable!!
So now she starts with the timing at full and the choke on
And then after a minute or 2 the choke comes off and the timing back to about 3⁰ btdc
And a fiddle with the throttle cable adjustment and BINGO!!
She starts easy and settles into idle and can throttle up with some spirit!!
Bjorn, You my Friend ROCK****************************************
Yeah Daryn,
I am Over the Moon that it is Running!!
I made a new right hand brake cable that is for the rear outer band. No front brake.
Took 2 tries but I got it to work. Had to file the cable slot for clearance for the pull and it is still a little bendy on the cable. so in the future.
I have been running it and she is a pretty good smoker when the cases fill with oil.
There is no other way to get it out but the drain plug. Or leaking out the the un-gasketed cylinder spacers onto the pipes.
That is something I believe I can remedy with modifications for riding the old girl but I am getting on vacation on Friday.
I am headed to my property Williams AZ, and dragging half of my crap from NJ to make my shipping Conex a little more livable.
It will be a Satellite for my getting the F out of NJ!!
Is it possible some of the smoke is coming from the piston blow-by due to the new rings not being fully seated? In any event, your progress has been impressive to this point.
Enjoy your vacation!
So it's very funny how these engines were built back then.
There's no evacuation for the oil. They pump it in but it can't get out unless you drain it
And the telltale sign of a full crankcase is lethargic running and smoking everywhere.
So this kind smoke of goes with the beast.
I revisited your post that mentioned this. Early in the thread you mentioned a hand pump that reclaimed the oil and put it back in the tank where it started from.
