This is a big shock!Don't do that - the oil check screw is too low from the factory, it needs about 200cc more than the oil check screw level.
At some point circa 2004-2006 the screw should have been made higher, but was not.This is a big shock!What is the background behind the oil check screw hole being too low?
thats funny my main rod bearing went too...i've since rebuilt the engine but still have clutch drag issues...i'm ordering a new clutch kit today...if it still drags after this then oh wellmy woes have continued tho not with the clutch but the motor having blown a main bearing at 2500km. It never ends!![]()
I thought I would chime in here and let people know the 449/511 have little to no clutch drag for some reason.
My clutch drag is getting unacceptable ... I had to change out the slave oRing today ...This again fixed the soft \ fading clutch issue but now the bike still wants to pull some with the clutch lever pulled in to the bar ..
Can the HYDO clutch models have the worn clutch rod issue as mentioned above?
