MasterChief
Thanks, I'll add one to my wish list.
EarthX 12A installed. Used weep holes in fender to secure vertically and metal side tabs to hold it back. Thin old wetsuit on back as a pad. Mounted low. Seat no longer rests on battery.
Rat tail file used to open the connectors for the screws a small amount. Pressed the starter and was stunned.... Spun so fast and lit up immediately, unlike the stock battery
It's tied to the fender on the bottom using the "ledge" that exists. The weep holes are low on that ledge, so they hold the battery from bouncing/moving vertcally and keep the base from moving up and over the ledge. The horizonatal tie keeps the battery back. By cinching the two ties up top I can keep things tight and not have the ties slip to the sides.What is keeping the battery from jumping off the fender notch if it isnt touching the seat? Im assuming you didnt zip tie it to the fender since that would make it hard to remove for filter cleaning. We are using a smaller battery on our TXC310R, but spaced it up so the seat notch still holds it in place.
The battery did not fit the tray and would need a fair amount of grinding to fit as I could tell. I was worried about wasting a good tray doing r+d as I'de have to thin the sides a fair amount.You should be able to still use the oem tray to add more battery support, it sort of locks the assy into place along with the zip ties. (No?). Thats how I did the smaller Ballistic mounting.
EarthX 12A installed...
Used weep holes in base of fender riser to secure vertically against bouncing and lock the bottom of the battery to the riser on the fender (since not using the tray). Used the metal side tabs w/tie to hold battery tight to the fender. Thin old wetsuit on back as a pad. Mounted low. Seat no longer rests on battery. Very solid and secure.
Very well. Turned over very fast and lit up immediatelyHow well does your 310R start with the Ex battery?
I apologize for the inconvenience you are having issues with your Ex battery, I have yet to seen one fail like this. I am happy that Ex is sending you a replacement asap. I am not entirely convinced that you didn't have a drain issue though, especially since your trickle charger was cycling the fuel pump, efi and starter solenoids.
