Tinken
I will be in Oregon coming up soon. I'll give you a ring closer to that date.Bring your bike, keep heading north after the race and meet me in bend for some high dez riding.
I'm actually starting to get a little concerned. This bike has always run hot -- to the point of boiling gas. And with summer approaching, things are only going to get worse. If the fan is running constantly in 50 - 60 degree temps, what's going to happen in 90 - 100s?
Are you referring to your TE or CR?
Accel pump on, though I'm not sure on the numbers. I recall they were base on my earlier understanding of the settings. I use stabil marine at the recommended maintenance amount per 5 gallons (either .5 or 1 ounce). And 4 ounces of Torco per 5 gallons. And always use Shell 91. I'll pm my map tomorrow evening. Thanks!You can send me a copy of your pc5 map and I can advise you. Do you have the accel pump turned on? What grade of fuel/additives are you using?
If it's XF2, typically it's only 1-2 psi due to the thermal expansion, at most 7 psi but you would have to have it pretty hot to get that high.Maybe Tinken can chime in and give us an approx number for the pressure drop in the cooling system. I think I read somewhere it was from 20psi to 5psi. Please correct me if I am wrong.
Properly maintained glycol coolant won't corrode either. Mine is two years old, and due for a change.The coolant doesn't corrode, it's the water that is the problem. Even EngineIce contains 7% water. We used to use Evans, but at 2% water, it would still over boil in extreme conditions. Our XF2 is anhydrous and contains only trace amounts of water. Like synthetic oil, the purity of your coolant will increase it's performance.
No signs of corrosion.
I appreciate the Evans doesn't require changing as mentioned, but I have no cause for concern with the standard cooling system.
Fan run very occasionally after lots of clutch work on hills, otherwise, it looks after itself.
Im in Redding, bring me some too...Enough for my 449 and 511...Then go roost Kelly for meI'm going to be up at Mt. Shasta in two weeks for the Western Hare Scrambles, I can bring it with me if you want?
The title was indeed 'better coolant ', yes.The title of this thread is "better coolant for my TE449" so I'm guessing he is asking about alternatives to standard antifreeze. He is asking if the XF is better in some way and worth it. It has a much wider operating range, runs at lower pressures and has no water in it which is known to corrode aluminum. Those are the advantages. Does antifreeze work fine? Sure. So do stock tires. He is asking about an upgrade.
Yeah I know that's why I'd rather send you. If you and your crew needs any info on places to stay while your up here let me know I'll try and help you out. I know all the dealers here and who to contact if need be. Some places are better to stay at than others.Haha, Kelly is a good rider, probably roost me.
It wasn't a shut down, just revisiting the original topic.The title was indeed 'better coolant ', yes.
No mention of XF or Zipty branding at all.
The factory fill coolant is rubbish, a better, readily available coolant is what I mentioned. The Nissan product is very good.
There are other products available, this is an open forum not a paid advertiser thread. By yours & others description Evans works too.
Thanks for the shut down.
The title was indeed 'better coolant ', yes. No mention of XF or Zipty branding at all.
No reason to get upset. Yes, evens, XF, water wetter... were discussing all of them here. Was not trying to shut anything or anyone down.
from the OP...
Is the XF Coolant I see on the site worth the money?
Which one would you recommend?
XF+ Race Coolant or XF2 Coolant?
I dont think I was out of line at all and not sure why you took it that way. All good.
