Better Coolant For My TE-449?
Figured I'd be wasting my time trying to help you, maybe the info will help other readers. To the OP, XF2 is well worth the investment, best coolant on the market at this point. Will never corrode or boil over to 387° :thumbsup:
No, not wasting your time.
As I said, I don't understand your concerns.
These bikes run a 1.8 bar radiator cap, even with plain water in them, they won't boil until 267deg.
Will plain water corrode - yes. Will it boil, yes, it stops cooling completely at this point and yes the system is under pressure. Will it freeze and damage your engine , yes.
Is it more efficient at removing & giving up heat than heavy viscous Glycol on its own - Yes, resoundingly so.
Does a product that has some of the properties of plain water with the benefits of corrosion protection and further overboil properties and antifreeze sound like a good idea.
To me yes.
Is it a compromise, yes it is.
Does it work if kept maintained, yes.
