MotoMarc36
Just to clarify. A linkage doesn't make a shock stiffer or lighter. It changes shock shaft speed relative to wheel position. I'll use whole numbers to make the math simple. Say your shock has a three inch stroke. And the wheel potential stroke is 12 ". With a "rising rate" linkage, as your wheel travels through the first 6" of travel, the shock moves 1" in its stroke. During the final 6" of wheel travel, the shock moves 2". Thus, you can see how the shock shaft speed increases as the wheel goes through its stroke. Manufacturers are constantly tweaking the rate curve and the shock valving in an attempt to find the "magic setting".
can even send the motor to ktm factory services and have it set up
