cgmjr
Today I got my old 83 250 XC back on the trail, after 26 years
I've just started the restoration, got a long way to go.
But on the trail today the power was awful. The engine bogged under throttle, and in some cases would barely make take-off in 1st gear. I've put on some weight, but not THAT much.
She starts easily, and idles fine, seems to rev fine in neutral. She has the stock jetting: 440 main, 45 pilot, 6DH20 needle, 166 R-4 needle valve. 38mm Mikuni, of course. The slide, however, appears to have been modified by hand from a 2.0 to a 2.5. I bought it from a racer back in 1985, so I guess he did that.
I've cleaned the bejebbers out the carb, but I have not touched any of the mixture screws except the idle.
Ideas? Are there any tell-tales signs about the piston or rings that might cause such poor performance?
Thank you in advance.
-cgm
I've just started the restoration, got a long way to go.But on the trail today the power was awful. The engine bogged under throttle, and in some cases would barely make take-off in 1st gear. I've put on some weight, but not THAT much.
-cgm
