Recommended Oil for TXC310R 2013
ThanxAndrew!
Think you sold me on it. I have been running Mobil 0-40 euro based off of Tinken in both the 310 and Tc 250.
I change oil if it even looks like getting dark. But also there seems to be hardly anything on the magnet drain plugs.
Anyone running this?
It's pretty close to OEM suggestion but 5/40 ?
ThanxAndrew!
I'm hard headed. I'm still running the Castrol 10/50 4T Racing. I think with the hot temps. the heavier oil will give a little better protection!? I don't know, just my semi-educated guess. It works well with my Rekluse EXP 3.0 but, I think the 5w/40 or the 0w/40 would work a little better with the EXP but, once again, just a guess. I'm like you as for as the oil changes go. I do it about every other ride. If it gets darker I change it. I've never been a big fan of sight glasses but, this one works for me. Rex
The 0W40 is superior for heat dispersion, per the manufacturer. I would have thought that heavier oil would cool better under extreme heat but according to research it doesn't. Must be that the bikes oil pump has to work harder with a heavier oil which equals less oil flow and higher oil pressure and the slower flowing oil has a better chance to overheat. That's my understanding in a nut shell. The 0w40 oil flows easier through the moving parts causing reduced friction and better heat dispersion.
