robertaccio
uh-oh ther's an "app" for it...
http://www.buildandclick.com/html/tuned_pipe.html
just drop it off at eriks, the guy with the WR250 with the vintage collection. He buys up about every DG pipe on ebay and makes em fit on everything, tellin ya, he would have a sweet pipe on that thing in about 45 minutes.
You rode with him at woodland trails, jake rode his bike up a hill, new husky wr250, super nice guy
Kelly, this sounds like an awesome build. The biggest problems with motor swaps in general, in order of difficulty to overcome, is pipe-frame clearance, pipe fabrication, and swing arm to case mating. With regards to the pipe and frame clearance, you have to raise the point where the cradle splits off from the frame below the steering stem. I think the easiest way is to get a YZ 465 frame, cut the cradle tubes out, and graft them onto the RMZ frame after lopping enough of the frame off to clear the 465's exhaust port. This method is elegant, in that your lower engine mounts are done for you already.
Yes, hard to put those first bikes out of your mind. If I were you.... Your TC250 and 400WR would be "The Frankenbike"!
Good luck I think the project is a fabulous idea. Please keep the photos coming.
I always thought my old 96 Yammy TT350 motor (air/oil cooled) with 6 speed box was a cracker in the bush. It would be brilliant with a modern frame and suspension. Might have to copy you.
Good luck.
I think your biggest issue will be getting more than 20-30 mins out of that little RMZ tank........![]()
So with all that I should be good for 45-55 minutes he he he Might not be able to ride the beast for longer than that. Might need to look into a case of rear fenders. I remember my YZ465 wanting to loop a lot, this should be worse.
