Well I got the hole drilled.
Used a #8 .199 drill with the cam cap as a guide. I drilled 13mm deep and hand reamed it to 13/63" ....the hole is straight and beautiful.
The stock bolt only uses 8 mm of thread engagement. No wonder it stripped!
Once my tap guide shows up I'm planning to tap 12mm deep and wind in a 10mm long helicoil insert.
I plan to order a couple of "longer" 5mm cap bolts that husky uses in the "long" holes with the dowels and cut it to get 10mm of thread engagement. I figure if the hole is 13 mm deep the "extra" 3 mm should allow me to counter sink the helicoil .5mm and use the remaining 2.5mm to break off the helicoil tang and leave some extra room for bolt stretch to keep the bolt from bottoming.
Does this sound like enough room?
I want to do this right and I'm acutally having fun.
