ive gone thru a gear lever in the 1st month i had my te449. my guess it was a pre delivery problem rather than a faulty part. it was replaced under warranty and after doing another 500km i checked the lever again b4 my last ride and it was loose so i tightened it so that it wld get me thru a day of riding. now im going to remove the lever to check and make sure that spline it ok and if its all good i will put it back on and try locktighting the boltMy mate has a 2011 TE449 and he has stripped the spline of 2 gear levers now. The bolt to tighten the lever is very hard to get at. Has anyone else had the same problem? If so how did you fix it so it doesn't happen again?
About half the bikes/atv's I service have loose shifters! It's something I check on every bike that comes through.
Yep, when you have a long lever you smash with your foot that's held on with a 8mm pinch bolt you need to check it often.
Apparently not, I did ask about 2 weeks ago. Definitely non in OZYeh im on my second. Is there any Aftermarket Levers around?
Same issue lads, lever comes loose regularily, installed a slightly longer allen key bolt and installed a lock nut also. Tighten bolt, then nut, then bolt and so on until its tight as. Has not come loose since. Its still a pain in the backside to get at and fiddly as unless you pull the swing arm out the way but, no pain, no gain !!!
