Doug Piper
Cannot see why its so difficult to tighten the bolt, just take the sump guard off, if that is such a pain what else are you not doing to your bike ?
http://www.mecasystem.fr/eng/pr/1000/husqvarna-skid-plate-449-te-am-2011-12.html
Totally agree, I even removed the swingarm and that didn't help much...Apparently you have not tried to access this bolt.
Either that, or you have some pretty fancy tools ...
The frame is in the way for a conventional, in-line approach to the bolt as a driver (or allen wrench using the long side)would offer.
And there is not enough room to fit a 1/4 drive socket and wrench in there - and no, you can't fit a flex end in either.
only a 8mm box end fit for me, and I could only turn less than 1/8th of a turn each time. I actually found a 2nd 8mm wrench that had a little different offset and alternated them.
World class pain in the ass. just a really poorly thought out design here (if someone actually put it into testing at all).
Now, I carry an extra lever, and those 2 little 8mm box ends with me on every ride.
PS did I mention red lock-tite ???
I also found it apparent to remove both the skid plate, and the chain as it offered more, yet still minimal room.
Last,
Good luck using a longer bolt with a lock nut on the far end. There is no room for that either.
Been there, thought of that, and found it just wouldn't work ...
Some here have said you can,
To that I say, pictures, or it didn't happen ...
But yes, from your comment, it is quite apparent you have not been down there on a 449/511 shifter "overhaul" ...
Guys guys guys......the middle of the bolt is an Allan key - takes a minute to get to!!
Yes, some do accept an allen key (my replacements were 1 with, and 1 without an allen keyway.Yep, that was a revelation for me, mucked around trying to get in there with a little socket, bending spanners to try and get in there, then discovered it was a socket head too.....doh
No offence taken bud - just a really frustrating job that on virtually any other job would be a 5 minute fix.I did not mean to offend you capabilites, i am considering passing this problem onto a very good friend who has some machining tools where we could remove some of the alloy near the bolt haed to gain better access, will update this thread in the future.
