rjdenya
Moose Racing sprocket from Dennis Kirk:Where did you purchase the 14t Renthal?
https://www.denniskirk.com/moose/sprocket.p844412.prd/844414.sku
thanks - I've bought a ton of stuff there, in my top three online retailers.
Does anyone run a 14 / 45 ? I almost never have my bike over 100 KMH and spend most time in town or on trails.
Me too.I'm running 15/45 ....works great. The bike runs roughly 4100rpm @ 105kmh .
KP
why 15/45 versus 14/42, easier on chain?
For me...it's because the bike came with a 15, and I already had a 45. But...all else equal, larger sprockets and chains reduce the speed of wear.why 15/45 versus 14/42, easier on chain?
The only time accelerated chain wear is really a concern, is when you get down to the 12 and 13 tooth countershafts.why 15/45 versus 14/42, easier on chain?
What is sixth gear like now? I don't think I want to go all the way down a tooth in the front - that's about 3? teeth in the rear? I really like being able to just lope along at 75 in 6th. Having said that, if I'm only going 70 sixth is actually a little too tall. I'm thinking of just dropping a tooth on the rear to start.
I, for one think the TE 630 has the sweetest wide ratio 6 speed tranny on the planet! You can lope along the trail in 1st and cruise comfortable on the highway at pretty much any sane speed you want. Go down a tooth on front or up two or three on back or both to suit your driving habits and you are good to go! Perfect!
I went with a 43 because Ironman makes a 41 or 43 (and other bigger ones), but not a 42. I dropped the countershaft to a 14 for the desired effect....the 43 was chosen because I didn't want to really gear it down, I would have likely selected a 42 Ironman if one was available.Stock sprocket is a 42 and you went to a 43? Everyone says the stock rear is aluminum? Hmmm...if I was changing would probly do 44 or 45 then. 43 is probly good though.
