Maybe it needs a damper.Glad you guys had a good ride John.
No instability issues at that speed with yours? Road neither? New posts on ADV about front shimmy at speeds over 75 on these things. Mine is a little scary over 65. Maybe it will settle down, maybe I'll get used to it.Maybe it needs a damper.
Getting dialed in for the DV trip.
Absolutely. Best mod yet.So if i want to leave the bike completely stock and just change the front sprocket to 14t it will still make a differance that is worth doing?
+1, although JD tuner is also a must!Absolutely. Best mod yet.
That's my problem, I use it around town and down the road too much to go up a ton in gearing. And I ALREADY find myself looking for 7th occasionally on the highway, haha.I just switched to a 14T CSS. Did some time in the desert this last weekend. Wow this is a legit dirt bike! For offroad I'd like even lower gearing. Rode to work this morning and it was noticeablely less fun to ride on the street (fwy) with the 14T. I found myself looking for 7th gear at least 5 times on my 22 mile commute. I'll be putting the 15T back on for weekday work.
Yes sir. It's well worth doing and can easily be swapped back for extended highway use. I probably never will but it's good to have an option.So if i want to leave the bike completely stock and just change the front sprocket to 14t it will still make a differance that is worth doing?
Hate to put more weight on the bike, but in this case it's an easy call. Steel rear sprocket is in my future.
Here's my OEM sprocket after 9000 miles:Below is my stock 42t rear sprocket after only 2,500 miles. Instead of spending money on a 14t front I opted for a 45t steel rear off an SM610. Like new condition for only $22 from Bill's on Ebay. 15/45 gives you the exact same gearing as 14/42 and I figure the steel sprocket will probably give me at least 5,000 miles greater chain life over the stock aluminum rear. Once the sprockets get worn, chain wear accelerates greatly. Also easier to install as no need to break the chain. I did at the same time as rear tire replacement so really no extra work.
I know a just a link is kind of a cop out, but it's a cool site to have book marked...I have 14T on the front but have considered putting the 15T back for highway miles. Would 14T front and 43 back improve fuel MPG and lower the RPM in 6th doing 70MPH on the freeway?
http://www.gearingcommander.com/
