organ donor
Donno why, but the permanently flashing neutral light is so annoying.
Just a guy at work clowning around.was the guy yelling at you for making too much noise? haha...
Have you or anyone you know had your speedo fail and had it replaced under warranty.
What were the issues?
My speedo jumped over 1000klm between 1 ride and the next.
The importer states it was tested and is fine!
Please post any speedo issues you have ever had with your past and current bikes.
Cheers
Stu
(mods: please make this sticky)
Sounds like it's losing power.
Cheers
Stu
What were the issues? My 2011 TE350 speedo got wet, caused a drain on the battery. Now disconnected I still have a small bleed on the battery. I can't seem to find the small bleed now. Any ideas would be greatly appreciated !
Cheers
Stu
I have solved the trip meter reset problem on my 2012 TE-449. Every time the starter would stall causing the 12 volt supply to drop below the reset point the trip meter would reset to zero
The first thing I did was increase the battery and starter wires to 8 gage ( both supply and ground) and installed a lithium battery. This helped but was not the fix, the starter didn't stall as often.
Now I have installed a diode in the 12 volt supply to the dash unit. The diode allows the 12 volts to inter the meter but prevents it from back feeding when the input goes low. Also I installed a 100 MFD capacitor on the meter side of the diode to the ground wire This capacitor charges up and supplies the power to the meter when the battery supply goes low. This has completely eliminated the reset problem. I installed these components in the pigtail that goes into the dash unit and covered then in hear shrink and tape. The diode goes inline of the "12 volts from battery" lead, pin one (1) on my dash unit. the ground is on pin two (2) of the unit.
Also I have replaced the lithium battery with a fresh lead acid battery and the starter has not stalled since. Or should I say yet.
I bought mine because most of the important electronic stuff is Japanese :-)Sooooo .... we didn´t buy Italian bikes for their world class electrics anyway!
Anyone got any tips on making the TE speedometer display the SMR speed. For 17" wheels. It says in the service manual a new dash can only select either mode the very first startup and that's it....
Anyway to erase it and start fresh so I can activate the smr 17" wheel speed? ?
