Kenneth Webb
Livin' It Up!
Booster Plug ordered!
My guess, and it is a guess, is that you won't be succesful. However, I think Cycra makes a Center Reach handguard which is longer than standard and is designed to go all the way to the bar mounts on the tripple clamp. You would have to experiment to see if thes will work, maybe with the Cycra fork mounts. Other than that, no ideas.Any of you guys have any luck with non-factory handguards? I'm looking for some that fit without removing the bar end weights. Preferably with an aluminum rail in them (not over priced touratech.)
Ogre, do you have to use a ring or open ended spanner to tighten the two bolts on the front of the oem bar clamp holding those PoweRisers? I have the Rox as well and found they twisted a bit, those PoweRiser look great.FWIW another riser/adapter option is the Powermadd PoweRiser 475.
I love this system as you not only raise the bar, but can postion it forward or back as well.
Similar to Rox risers but being a 1 piece design they a lot more soild.
I have both and I can twist the ROX set up, but not the PoweRiser.
Nice looking setup. Where did you get the Acerbis handguards? I can't seem to find them?New Easton bars, Acerbis "air busters," and Motorsportz clamps. The Acerbis are not metal reinforced so I'm sure will break upon impact, but the color scheme is perfect and should help some in the cold weather.
I added these PowerMadd Star series handguards for wind protection. No aluminim rail, but simple to install/uninstall. They seems to do a fair job. I went for a 30 min ride at 37F and it was tolerable.
Thanks for the link. I think the first order of business will be to get mounts and bars ordered.I got them at a local Honda dealer, but here is a link...
http://www.acerbis.com/handguards.php?idp=3648&ids=39&id_categoria=5
Note they will not work with OEM bars as the ends are closed (I supposed you could improvise). They will not work with the Motosportz/TrailTech bars either as the bars ends will not accommodate the Acerbis inserts.
Going for it. I ordered the HDB guards, top clamp, bars and anti-vibe inserts. Now I need the risers from Motosportz and that is in progress, I hope. HDB stuff is really top, and I'll be returning my Acerbis guards which just arrived this evening. I have HDB on the 630 and I don't think there is anything better (or more expensive!). I took IPA Brewer's lead and got the Henry Reed bend, almost the same as CR High. Ordering bars and guards thru HDB means they are pre drilled and tapped for the inserts, and the guards should fit pretty well. One problem coming up though is the key access. The HDB top clamp will cover it partially but I think trimming the key head will take care of that. I hope! The heated grips will follow, even though they may not work very well on the aluminum bars.
Just got the Touratech handguards. Easy installation and don't need to cut the levers nor reroute or move anything. I ordered the white handguards plus the red spoilers. They are all plastic but they look good anyways...
Picture is not great but here it is:
Close up shot?
Very Nice. Im going to get those ones. The match the body work of the bike nicely.
Thanks and Cheers
they do look nice but $119 for the guards and $32 for the spoilers plus shipping you could get some HDB's which IMHO would be far more protection.
