Well thats weird.
BTW it was troffers bike R&B did.
PC.;103399 said:I saw that too. And he would know.
I'm sure its fine. Just a different skirt design.
I assume the Vertex piston is the same!?!?
Johnny,
can you verify? Did you get it yet?
Also, I tried to measure the squish with the stock piston but the 3/32" rosin core solder was too thin to impact the head. So the stock squish is greater than .094", which is really loose itself. I'll need some thicker solder to get an accurate reading.
! 71,945mm in diameter and tefloncoated.
MOTORHEAD;103524 said:You might take a look at your air boot to box seal and make sure you're not sucking dirt. That sand blasted look on the intake skirt might be a sign.
Just saying.![]()
PC.;103599 said:If anything it was from the Mikuni sucking dirt before I got the 7602 filter on there. There was always dirt in the carb when I'd pull it.
PC.;103598 said:Johnny,
can you post a picture of the intake side of the piston please?
Foggen33,
there's an A, B and C sized piston. A is 71.94mm, B is 71.95mm and C is 71.96mm.
If you remove the head you can see what size piston it currently has.
Foggen33,
Johnnymannen;103903 said:Hello Swedish friend! As i have a few hours left on my piston it will take a while before disassemble it. I don´t know if it makes any special differenc if the piston is 71,94 or 71,95mm as standard when my piston is in between at 71,945mm. Thats 5 thousands! I guess rhey make the piston like that to fit both sizes.
What do you think?
Johnny
Foggen33;103909 said:Question: Is the head sealed with o-rings or what. Do I need to change anything or can i just lift it off and put it back without risking any leaks if i ride for a couple of hours? This is my first 2-stroke ever so I am not so familiar with them.
Motosportz;103969 said:0-rings. Real EZ to do. Pop it open and take a look and slap it back on. Should not take more than 45 minutes.
PC.;104055 said:Not really looking for more power. Just want to shift some down low (where I spend more of my timer riding this bike) and less up top. This bikes makes my YZ feel tame on top and the YZ makes this bike feel tame on the bottom.
And I am a self proclaimed power junkie and I cant leave well enough alone. No point lying!
Johnny,
any chance of getting a picture of the intake side of the piston? Please!
