TE630 dyno results and thoughts
Discussion in '610/630' started by DYNOBOB, Apr 29, 2012.
  1. dirtyrhode Husqvarna
    te630
    Can anyone tell me if your gettin a searious power increase from removing the air box snorkle or modding the lid? Or if its even worth doing.If so, what exactly should i do? THANKS
  2. dirtyrhode Husqvarna
    te630
  3. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    ^ dirty
    Look at the 610 air box, look at the 630 air box...
    I cut open the air box as much as I could behind the side panel, p/u done, single exhaust, iBeat 105/110/120, 3.0 gearing...WAY better then stock!
  4. WickedWill Husqvarna
    QLD,AU
    some little red ones
    Bob did you get around to doing this?
    I am still trying work out why i can't access CO settings.
    The bazzaz o2 eliminator measures 9900
    When i stick in a 2200 ohm resistor,the homemade pu mod, i get a o2 heater circuit fail.
    Was wondering what PC-V where using.
  5. WickedWill Husqvarna
    QLD,AU
    Edit:
    Found out the the resistor i was sold as 2200 ohm were the wrong ones.Had a couple of different watt ones but all 22000 ohms,just checked the colour bands to work it out.Back to pulling the tank and try a 2200 ohm resistor to try to work this ibeat no CO issue.
    Map wise i have applied smooth to the bazzaz map and it well smoothed things out.Can hold low revs at a steady speed no surging and it just sits there.Should be able to pull good economy.
  6. DYNOBOB Husqvarna
    I never did compare the two plugs. I could measure the stock plug if you'd like.
  7. mekanik Husqvarna
    Kootenays, Canada
    I made my own plug using a Radio Shack 2200 ohm resistor. Works great.
  8. WickedWill Husqvarna
    QLD,AU
    That works without a aftermarket fueler.What I am trying to workout is what power command and bazzaz use.If my 10k pu plug is a fried one or why they need to trick the circuit with that high a resistance and if that is causing ibeat not to open the CO command.The good thing I can build maps around what values I am stuck with in ibeat.
