TE630 dyno results and thoughts
No doubt the Leo full system wakes the bike up and I agree, it appears it wants more fuel on the big end. I can't get my mind around a $1000 exhaust for this bike though...
I messed with the bike again today and am feeling a little better about things now. I wondered if I had a fuel issue and that turned out to be the case. The "Unleaded Fuel Only" sticker on the tank led me to believe that premium was unnecessary so I've been running regular unleaded (every other vehicle I own that requires premium says so). Everybody but me probably knows this is not the case. So I removed the 87oct and refilled w/ 93oct. Well that made a big difference. The bike is still lean but is much happier w/ premium. That made me wonder if it would like even more octane so I drained the 93oct and refilled with 100 LL (av gas) I keep around for my chainsaws. It also likes the 100 LL. Still need to add fuel but it's going the right way. NOTE: I'm not suggesting you run 100LL, I tried it because it has the effect of richening the bike up. The cats would not like the lead.
The other thing I did was test with/without airbox divider. No surprise the divider costs hp (but did smooth the curve).
So my best pull today was with the 100 low lead.
And finally I pulled the 630 and put the '09 KLX250S on. I was very happy with it making a little over 20hp. Everything I've seen reported said 17-18hp. Below is TE and KLX.
do not use av gas
hopefully your use of 87 octane since new hasn't put a hole in the top of the piston crown from detonation
In regards to octane rating, I was told to only run premium, so i run 95 octane and 98 - or on the rare occasion 100 octane if i can find it (of course, i am in Australia and our regular is 91 octane)
I use the highest octane I can get that doesn't contain ethanol.
I feel dumb asking this, but don't all the gas stations sell gas with 10% ethanol? If not, what stations don't?
Edit: I just found out that over 5000 stations still sell pure gas, just not in Ct. I also found a cool app called pure gas for iPhones. It give you the 10 nearest stations + directions to them.
Geez, there are 5 (FIVE GODDAMMIT) in CA that are 'pure' gas stations. ;)
And NONE of them are anywhere near the LA basin.
No wonder gas goes bad in a couple of weeks. The carbs are the worst. I'm going to invest in pilot jet stock. :lol:
If you're not using the O2 sensor or the catalyst there is no reason to run unleaded fuel (outside of befriending the tree huggers). Mix some 110VP or 110 Sonoco with no alcohol 93 pump, you will like the results and your valves and valve seats will thank you for the lead.
In this area, we typically have 3 grades to choose from:
87 (pure gas)
89 (10% ethanol)
91 (pure gas)
There are some stations that put 10% ethanol in their 91 octane as well as the 89. If that's all that is around, I use 87.
So I just check the app and I can't even make it to the nearest station on a tank of gas. Just my luck
I can't even get ethenal free, never mind leaded gas...
The app is crowdsourced and is pretty sparsely updated, at least in my area. It also gives no provision for adding locations. So, if you can't update it from your phone, how can they expect a bunch of data input?
not to side track this thread anymore than it is, but here is a map of all pure gas stations
http://www.pure-gas.org/extensions/map.html
when I get a chance I'll post the Leo Vince dyno chart which, needless to say, differs tremendously from those already post. But what is also different is where the motor is making (rpm range) max torque and hp.
I get a notice on my phone for an app upgrade and it refreshes the data (I'm assuming) It might be up to the stations to notify puregas because I have found no ethanol stations that were not on the app.
I get my VP110 from a machine shop that builds racing engines but I have bought Sunoco 110 from a NAPA parts store. If I were you I'd ask around, I guarantee local drag racers aren't using pump fuel or they would be going through race engines like toilet paper.
Interesting, most stations in OH are marinas. None near me unfortunately.
Seems to me when this ethanol thing really got going the boaters were trying to get the marinas exempt because the fuel is so hard to stow onboard. Phase seperation is just awful and it corrodes the marine engines. Makes a real mess of things. If you think its hard to live with for bikes it's way worse for outboard motors.
