wallybean
Mini-Sponsor
I am not surprised at all by the spring results. The best option for the newer power valved engines with any adjustment to the linkage is white outer at the least in conjunction with an inner. If anything with the 125 motor I would use the stocker and maybe the silver or green spring. The 144 will be more forgiving but will still like the white or stiffer outer.
The best powerband I have experienced with the husky 125 is an 04 CR with the yellow and green. This is the older style PV's and porting.
My 167 doesn't like the linkage adjusted at all up. Again it uses the older PV's and porting. It has the very best powerband of any small bore Husky I have ridden. Of course I like torquey motors with an angry personality when you really need it. It will tackle anything the 144 does a gear higher with no fuss.
I will be doing some more work this winter to try and offer more options with the linkage adjustment in mind.
Gsxr1000user,
Yours and Darty's work is phenomenal, keep it up. I love instruments that don't lie, even when our butt dyno disagree's.
Gsxr1000user,
