Well, bit the bullet and purchased the bike.
Haven't bought Second Hand Bike for years, and what a complete disapointment it is that some people have no idea about Bike Maintenance or even Cleaning a bike properly
Spent 3 hours cleaning it and going over it, truth be known, had i known what i know now, i wouldn't have purchased it.
1. Incorrect Bolts used in a few places
2. Black silicon used to cover up holes that hold the Radiator Shrouds on to the tank (where the middle bolts would have gone)
3. General damage that you wonder "how on earth did that even happen?"
4. Back yard mods and slack workmanship.
After spending some time going through the bike, it is in better shape, but needs $500 spent on it.
My first Fuel Injected bike....
Starts amazingly well, No Choke, just starts and idles.
First ride... Mmmm interesting motor.
Huge flat spot off the bottom in every gear (its like a hole), then the mid hits hard-ish, almost like the fuel mixture sorts itself out, then off to the top end which is there, nothing special.
My YZ250F pulls harder off the bottom and faster too. Not sure if its the extra fly wheel weight or what?
And the worst bit, is the noise the thing makes, dam its LOUD!... Have the baffle and spark arrestor out and the tip removed.
Expected it be a little noisy, but not in an annoying way! My YZ250F with a motorcross muffler is much quieter.
Brakes very well, Steers well, its a bit "Rakey", but to be expected coming from a YZ250F.
Feels solid all bearings are tight as a drum.
Will set up Suspension Sag next, New grips, General Ego adjustments, Change Engine Oil and Filter, Get some new bolts and see where that gets me
Actually it may need to Valves doing... Few pops and farts under back pressure.
Happy with the purchase over all, it just needs some TLC to neaten things out and correctly address some poor maintenance issues.
