The Bergs are more different from KTM's, than the naysayers believe... Husaberg tanks are different from KTM tanks, that are larger yet slim, their own suspension settings, engine mapping and now plastic subframes that change the feel of the bike.
Coming off a bunch of Huskys, it was different at first and took some setup. It was a steep learning curve, as all my Husky buddies were of no help and a bit down on it. Ask a Husky guy what it takes to make PDS work and he says either... "It doesn't or a $5000 Hard Parts shock."
After a bunch of small steps and too much time on KTM Talk, I was gaining ground, but not quite there. I went down to do a bike set up session and riding lesson with Rich Lafferty. The Lafferty's know a little something about KTM and Husabergs! Rich thought the things I'd done, were in the correct direction.... shorten wheelbase, switch to 20mm triple clamps (which Husaberg did on '13-'14 bikes), bar location front to back in triple clamps, suspension settings. He thought my bars were too high and my static sag was off. We swapped to a higher rate rear spring and went riding. The bike was much better turning and working better overall. We rode for another 3 hours, working on my standing position and a bunch of other things.
For homework, he suggested that I lower my bars to stock height, but to first do an experiment. He said when you get home, lay out a figure 8 grass track and ride it sitting and standing with your high bars. Then I want you to ride it with low bars and see which feels better. The low bars had much better front end feel and traction and made the bike what I wanted. It will never handle quite as well as a Husky, but damn close and the e-start and adjustable PV set up make it nice for an old cripple like me. I'd be curious what the Husky/Husaberg version of the 200 would be like, I'm thinking it would be better than KTM's
For those who don't want PDS, the Husky MX models will have linkage and there may be XC models with linkage too.
