Tinken
The impellers are metal but you will need to test to make sure seals are still good. When you take your clutch out, feel for excessive play back and forth on the clutch basket because you may have melted your rubber bushings. Also, check valve adjustment. Change clutch fluid over to Dot 5 or fancy stuff Nantista runs. What saved your engine was not the quality of the oil, but the viscosity and flow. Oil is a coolant.
When is your next race and where?
