Flaming out, cough stalls and false neutrals, 14 250r
Bike was busting my brain today with it's cough stalls and flame outs.
Also had a fair few false neutrals.
I wonder how much is to do with motul 7100 oil and the fact that the bike only has 200 miles on it so far.
I didn't notice it flaming out this much last ride.
Anyone else get it on their 13/14 bike ?
It's happening to my bike as well...14 TE310....I just remapped to power up- Leo Vince tune and seems to be better but dealer reassures me this is typical to the Husky and should be ok around 500 miles..I just hit 200
My 2014 TE310R is doing that same thing and driving me nuts! I put the DB buster silencer in and after slow technical riding I get the Pop & Stall! In an attempt to fix it, I realize now that moving the TPS was a bad idea, but I wanted to do something. So, my dealer says he cannot adjust the TPS without a computer... Any suggestions are welcome to get this bike with ~150 miles back on the trail.
Yea me as well...we are going to adjust the TPS tomorrow....my buddy has a ktm 350exc and has the same throttle body and sent his out to make his bike run better which it does...gonna try the same thing and hope it works...
Are you going to attempt to do that by sound feel, or do you have a computer device. I have heard that you can never get it right without the computer. ??
My final sea level autotune generated map for the '13 TE310R with the stock pipe/no cat. Check the numbers on the table below... For the most part open map 3 slightly rich (stock 12mm sensor I pulled dark with soot prior to install of 18mm sensor and dyno run). Probably good with an open pipe but does indeed run better now with this trim. Even at startup runs as it should requiring a hint of choke. If so inclined get a PCV (special order required) and transpose these trims or I'll post the map. Will be generating a high altitude map as well for (8k and above).
My final sea level autotune generated map for the 310 with the stock pipe/no cat. For the most part open map 3 slightly rich. Probably good with an open pipe but does indeed run better now with this trim. Even at startup runs as it should requiring a hint of choke and will pop/stall until warm if you crack the throttle fast.
If it starts to die or flame out when you first whack the throttle open, you can adjust the accel pump feature.
Not sure if I need to adjust it but just seemed the way the bike should warm to tenp. Once she warmed for a minute all is good. Ran it on the street 2 days ago to redline through the gears.... Yee Haw! Steady idle and not a pop.
  • Like
Reactions: JAM
My buddy is using a volt meter to dial it in....the guy that did his ktm told him how to do it otherwise I'm hoping that it stops regardless around 500 miles like the dealer said?? I'm going to keep my fingers crossed
Adjusted TPS to .70 and no stalls tonight but only did 10 miles...going to do some single track and really test her tomorrow ...BUT no stalls...OEM TPS setting was .58
  • Like
Reactions: JAM
Tinkin, are you saying the map can not be adjusted on the 2013/14 TE310/250 bikes? The Mikuni FI was tunable with ibeats, is there no programming tool for the Keihin unit? My bike (2013 TE310) flames out at low rpm throttle opening, very annoying. I've heard about an "accelerator pump" feature. Does such a thing exist and how do you adjust it? Is there a procedure to reset the TPS without a programmer? Can the issue be resolved without shelling out $$$ on a piggyback tuner?
Ok, so the accelerator pump feature is a power commander thing, correct? Not available as an adjustment to the stock ecu...
Not looking to hiya-jack but I was under the impression that EFI bikes did not have a need for an accel pump type action ... Is this feature on all bike EFI systems or just the current EFI on the Huskies?
If you know how carbs work and have done a lot of jetting the amount of new control is compelling with PCV. Having a set map which may not have been acceptable in the old days with carbs, is acceptable/mandatory today since you are locked out. Nice to be able to plug in the usb from laptop or windows tablet and adjust all parameters. Then not having to pull a set of carbs off the bike and dismantle to get to the jets, etc...
