Ok, We usually get run thru those sappling trees that wack you pretty good. So your line got me thinking. Yes might be one in a million but that 1, usually happens to me.
I spent 8 hours and welded up 3 designs. 1 with plated aluminum. 2 with rodded and plated aluminum. 3 just rodded aluminum (My favorite).
This is by far the best I came up with.
My thinking in this design is:
1. Won't restrict air flow.
2. To get high enough on line, I had to come off the chain tensioner, thus using a longer bolt.
3. Didn't want to bolt to motor mount and felt the motor mount bolt, might come loose attaching a softer metal to it.
4. Just drill and tapped the frame.
5. Since going off case bolts, I wanted something to give on a big impact. That is why i designed it with and S towards front so it can give. Actually, this is solid as heck but I know it will bend before busting the cases or pulling the bolts out.
6. Bent one brace so that my lil funnel fit.
7. Oil cap access no problem.
8. Keeps the oil line back against engine.
9. In the pic I threaded on a 1/2 in Zinc compression spring as a test. Going back tomorrow and getting a longer one that will run whole length of line. I basically threaded it on the line. All the way at the top, I crimped the spring tight. So if something tugs on my line, it has to pull the spring as well. I also will crimp the spring on bottom tomorrow.
10. Won't affect the line if needs to cool.
11. If you want to use a skid plate or another guard, should not be an issue.
12. Doesn't cover the HUSQVARNA on cylinder.
13. I think it would be reasonable to fabricate and passed to consumer. Oh, yeah different anodized colors. Red, Black, Silver? If you are interested in making these in mass production, PM me.
End result is, I think this will be better than nothing. Is solid but not to the point it would bust my cases in impact. I almost put more braces in it but I think if it is too solid, It will cause damage.
Your Thoughts good or bad?
Oh, it is an optical illusion but bottom of oil line is right behind the aluminum rod and is protected. Just doesn't look like it.
Hey it's winter and I am not racing yet.
